![]() Drives: 2010 Camaro 2SS/RS ABM Join Date: Apr 2017
Car making weird cranking noises at start?
Hey guys!
Typically, a car makes a small cranking noise before starting. My car starts up in the morning after hours of not driving it. (Normal start up) However, when I turn off the car and turn on the car again between minutes or seconds later, my car starts to crank more and doesn't start up normally.... THis morning, I turned off the car in traffic, and as soon as I turned it back on it briefly said "Service Stability Trak" then the message went away instantly and the car began to run normally. I figure every time it says that "Service Sta[...]" It can be related to sparks plugs. Could it be that it's not injecting enough fuel? The car runs phenomenal at the first start up of the day. |
![]() Drives: 2011 Camaro 2SS Join Date: May 2016
My service stabilitrack light and traction control light comes on when my battery starts to fail, may need to look into how low the battery is, even if its a small amount low, these cars are super sensitive to it.
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: LT W/2LT,blue metallic Join Date: Jul 2016
yup,mine came on yesterday,then has been ok afterward.battery is original(2015)
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
I'd say the battery is starting to go.
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
I had the same problem and replaced so many things and did nothing. If it's not the easy parts like battery etc then u prob need a new ground added which solved my problem.
Pity a man in familiar places, who yet feels like a stranger.
#6 |
![]() Drives: 2015 Camaro 2SS Join Date: Oct 2016
Mine was similar, new battery, extra ground wire and a new starter seem to have fixed things.
Personally I would try the battery first and see if it fixes it. |
| Tags |
| problems, startup, wtf |
