06-23-2018, 01:52 PM | #1 |
tweeter placement assistance
I just bought a set of the focal 165 AS speakers and the tweeter is too big to fit in the factory tweeter plastic casing and the plastic casing that comes with it is way too large to even dremel out and fit in the factory location, is it ok to just hot glue the tweeter into the triangle housing and put dynamat or something behind it to hold it in place better or is this unsafe?
*Performance:
mrt v2.0 exhaust/CAI Intake *Cosmetic: Zl1 factory Reproduction wheels Bmr 1.2/1.4 springs/Oracle plasma drl lights, footwell ambient lighting, 45th Gobo lights *Audio: Memphis pr600 amp/Fosgate 12" t0 sub/******** stealth box |
06-23-2018, 03:18 PM | #2 | |
Drives: 2011 2SS/RS Join Date: Feb 2016
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
06-23-2018, 03:34 PM | #3 |
That looks awesome but slightly more fabrication involved than I trust myself doing lol. I had a hard time trusting myself to cut out the speaker brackets, don’t think cutting up my a-pillars are in my near future
*Performance:
06-23-2018, 08:51 PM | #4 |
Most aftermarket tweets wont fit there unless ultra tiny. use hotglue to hold them, and when you want to do more fabrication and move them, you can have them removed. easily pliable.
06-24-2018, 11:21 AM | #5 |
Does this look alright? Figured the foam would help just to be safe in case the glue didn’t hold, and it shouldn’t affect sound or get warm since there is no woofer correct?
*Performance:
06-24-2018, 06:38 PM | #6 |
It should work fine. just be sure its secure
06-26-2018, 08:46 AM | #7 |
ILSQ
Drives: '13 2SS/RS Join Date: Feb 2017
Nice workaround! Looks great.
Way too many mods to list, and just getting started...
