Old 11-22-2009, 08:23 AM   #1
FISHTAIL
FISHTAIL's Avatar
Drives: Sedan & 2SS / RS
Talking Just Installed the SS mufflers on my V6
I was looking for a way to upgrade the look from those smaller V6 exhaust tips to the more muscular 4" SS tips while still maintaining the stock look. I saw a pair of SS mufflers available at Ebay and I decided to buy them, mainly for the look. I thought that the mufflers would be basically the same, with the only difference being the tip size. Boy was I wrong! There is definitely allot less restriction on the SS mufflers and they weigh less too. The SS exhaust tips not only look way better, but the sound and tone has changed allot. It sounds louder more muscular with a rumble and a growl. LOl
By the way these muffllers are off an L99 Automatic trany SS according to the seller wich was a GM dealer, they had aroud 500 miles on them so they're still braking in. I can tell by the smell that they're still braking in. I expect them to develop a even deeper tone when they're boken in like my original ones that had aroud 3,800 miles on them.
At the begining of the video is getting reved from 3-5K towards the end I have my friend rev it to about 3500. At bit raspy around 5k but I think I'll tone down after some carbon deposit after another 3k miles or so.
Drives: 2012 2SS/Black/RS/A6
FISHTAIL is offline   Reply With Quote
Old 11-22-2009, 08:48 AM   #2
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Drives: 2010 Camaro 2LT Rally Yellow
Originally Posted by FISHTAIL View Post
I was looking for a way to upgrade the look from those smaller V6 exhaust tips to the more muscular 4" SS tips while still maintaining the stock look. I saw a pair of SS mufflers available at Ebay and I decided to buy them, mainly for the look. I thought that the mufflers would be basically the same, with the only difference being the tip size. Boy was I wrong! There is definitely allot less restriction on the SS mufflers and they weighs less too. The SS exhaust tips not only look way better, but the sound and tone has changed allot. It sounds louder more muscular with a rumble and a growl. LOl
I will post some Videos when I get a chance.
Well that's thinking outside the box. May I ask what you paid for the mufflers?
67 GTO is offline   Reply With Quote
Old 11-22-2009, 08:54 AM   #3
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Please post up sound and video ASAP!!!
Old 11-22-2009, 09:05 AM   #4
Orange5thGen
Orange5thGen's Avatar
Drives: 2011 Convert
Send a message via Yahoo to Orange5thGen
I have seen a few on Ebay cheep
Orange5thGen is offline   Reply With Quote
Old 11-22-2009, 09:06 AM   #5
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
Good idea! A V8 flows a LOT more gas than a V6, so you should have gotten a bit less restriction too.
patriotpa is offline   Reply With Quote
Old 11-22-2009, 09:08 AM   #6
FISHTAIL
FISHTAIL's Avatar
Complete set up installed $160.
Old 11-22-2009, 09:19 AM   #7
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
The SS exhaust flows through 2.5" pipes instead of the 2.25" pipes on the V6. That may have helped a bit too. Did you replace the entire exhaust with the SS setup or just use adapters to make jump from 2.25" to 2.5" at the mufflers?
This is an old trick that the V6 Mustang guys have been doing for years. They just use take off exhausts from the GT models when guys upgrade to aftermarket kits.
I didn't actually think it would make much of a difference with the Camaro though since the two systems are pretty close in size and design.
rolnslo is offline   Reply With Quote
Old 11-22-2009, 09:19 AM   #8
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Very nice inexpensive upgrade, you may start a trend.
Old 11-22-2009, 09:26 AM   #9
Easy Go
Easy Go's Avatar
Drives: LLT MV5 B34 N65... period.
Just make sure the SS exhaust doesn't end up any closer to the plastic trim than the original. You risk causing some very unfortunate meltage.
Easy Go is offline   Reply With Quote
Old 11-22-2009, 09:27 AM   #10
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Nice thing about the 2005+ Mustangs is the mufflers are simply bolted on! No cutting to switch from the stock V6 muffler to a take-off GT muffler... simply unbolt and swap mufflers! The V6 Mustang muffler was incredibly restrictive... swapping to a GT muffler was about a 10 RWHP GAIN!!
scrming is offline   Reply With Quote
Old 11-22-2009, 09:33 AM   #11
FISHTAIL
FISHTAIL's Avatar
before they welded it on I make sure that it fits perfectly in the center.
Old 11-22-2009, 09:37 AM   #12
Easy Go
Easy Go's Avatar
That's good that they are centered, but is any part of the exhaust closer to the trim than it was before?
Old 11-22-2009, 09:43 AM   #13
rolnslo
Rolling along...
rolnslo's Avatar
Why would this be an issue? The stock SS exhaust exits through the same size holes in the rear diffuser so putting the SS tips through the holes on a V6 diffuser shouldn't be a problem as long as they are centered.
Now, in my case, I've got 4.5" tips (vs. the 3.75" tips of the stock SS) with the SOLO Mach XL kit so there is very little clearance going through the diffuser but I'm not having any issues with melting anything after having driven a few hundred miles.
Old 11-22-2009, 09:45 AM   #14
FISHTAIL
FISHTAIL's Avatar
The muffler I bought had about 2" worth of piping so the muffler shop streched it out a bit and sleaved it over the original piping on my V6 and welded it on. The whole thing took no more that 20 minutes. Faster that my last oil change Lol
Magnaflow 2010 Camaro SS Systems JDP Motorsports V8 Bolt-Ons & Tunes 61 12-12-2009 01:13 PM
TRADE ME YOUR FRONT SS FOR MY V6 FRONT!!! n-shane@hotmail.com Exterior Parts & Accessories 8 11-30-2009 04:07 AM
Differences between v6 and ss Blacc Mamba Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 4 09-23-2009 08:17 AM
Camaro LS / LT / RS / SS specs and options! CamaroScotty 5th Gen Camaro SS LS LT General Discussions 119 09-02-2008 10:46 PM
