07-01-2018, 01:46 AM | #1 |
Yee-aay-ee!
Drives: 2015 2SS/RS CV CE Join Date: Nov 2015
It's been 6 years... LLT vs LFX Durability
In 2012 the Camaro went from the LLT to the LFX engine, which has 11 HP more & weighs 20 lbs less. It's been a few years, so which engine has proven to be more reliable? Is there a difference in dependability?
07-01-2018, 02:23 AM | #2 |
Drives: 2012 Camaro 2LT RS Join Date: Oct 2013
Interested!
07-01-2018, 05:20 AM | #3 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
good question.you probably dont hear about the ones that keep running,just the ones that grenade.lets hear from some owners ...i have 33,000 miles on my 2015,never an engine or transmission issue.
07-01-2018, 05:50 AM | #4 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
2 guys I work have a 2010 and 2012 v6. Both guys love them.....neither has had one single issue.
07-01-2018, 07:20 AM | #5 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
I money shifted my first LFX at 62,5xx, my current has been in my car for another 40k, never had an issue with either (sans money shift, LOL)
I believe only the early 2010 LLT Camaros had any kind of real issues, and once the timing chains (and whatever related components, I don't remember what exactly) were changed, the V6 platform hasn't had any other major issues.
07-01-2018, 09:56 AM | #6 |
nobody else wants to play?there have to be a few with more than 33,000 miles on their cars...
07-01-2018, 10:02 AM | #7 | |
Drives: 2010 2LT/RS Join Date: Mar 2015
I had about 40k miles on my 2011 2LT before i sold it with no engine or transmission issues. The same applies to my current 2010 2LT which has now 85k miles with none of the above either. Both vehicles just went in for normal routine maintenance.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
07-01-2018, 10:57 AM | #8 |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
I have just shy of 80,000 miles on my '13 LFX, regular oil changes first with DEXOS, the last couple of years with AMSOIL XL and no issues. No trans issues at this point either, just a change from factory fill to AMSOIL SEVERE GEAR about 35,000 ago.
Don M
Supercharged LGX + 6 speed manual = FUN!! |
07-01-2018, 10:58 AM | #9 |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
I thought GM changed the oil change interval algorithm on the LLT at some point because it was too long or something? I'm sure the number of failures are rather small but its the bad news that gets reported more often than not.
07-01-2018, 11:24 AM | #10 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
92,000
No Engine or Drive line problems if the radio hadn't went bad, i'd had no problems
Hot Wheels Emblems and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills, Hot Wheels door Sills.
07-01-2018, 11:26 AM | #11 |
Fish Poop Aficionado
I’m at 42k miles with my LFX and I bought it at 36k. So far, no real issues. However, my CEL did come on for about 15 seconds and then went away a few days ago. I’m pretty sure my oil pressure just got too high because I gunned it to pass somebody and I had already driven a few hundred miles on my way to the beach. Other than that, no problems.
07-01-2018, 11:28 AM | #12 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
My LLT engine has ran strong with over 17 PSI of boost on stock pistons. Too bad the 6L50 transmission wasn't as strong, broke the input shaft on it. The LLT also survived 8300 RPM'S when that happened
07-01-2018, 11:55 AM | #13 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
15K on my '12 with one issue so far.
The torque converter was replaced under warranty with a '13/'14 TC at roughly 8700 miles. Known issue on the '12s consisting of a rumble when cruising around the 41 to 44 mph range but fixed on the '13s. Engine just purrs.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
07-01-2018, 12:09 PM | #14 |
Drives: 5th Gen L99 Join Date: Nov 2017
I haven’t done much research on those motors, but 8300 rpm is quite a lot.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
