![]() Drives: 2015 Camaro 2SS RS package. Join Date: Oct 2015
Recomended thicker oil in the rear diff? 2015 Camaro SS
Hello im currently on the stock fluid but my gaskets are leaking fluid on the rear diff. I am planning a full gear and new seals rebuild soon, but wanted to fill with a heavier oil to avoid quick leaks while I source the parts.
What is a good recomended rear diff fluid that is thicker than the norm to use? Thank you.
2015 Camaro SS / RS package 6MT Summit white
AKA Casper. Hurst Short trow shifter and bushings. Cold Air Inductions cold air intake. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: cars Join Date: May 2011
You need a new gasket not an out of spec oil.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS 2SS M6 Join Date: Aug 2016
you need new axle seals...these diffs use synthetic due to tight clearances....I upgraded to Royal Purple...good luck!
peace
