Yee-aay-ee!
Drives: 2015 2SS/RS CV CE Join Date: Nov 2015
The Camaro V6 went from the LLT to the LFX in 2012. When were the low oil level indicator & upgraded PCV valve added?
I've been seeing online statements that it was model year 2013 & others that it was with the 2014 refresh.
Drives: 2013 1LT RS Camaro Join Date: Apr 2016
The PCV upgrade was in 13, don’t know about the oil level. PCV was late 2012 manufacturing ,so late 12’s and all the 13’s.
Yee-aay-ee!
So is someone able to confirm if the 2013 V6 has a low oil level light?
![]() ![]() ![]() ![]() ![]() Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
My early 2013 and my friend's late 2013 both have low engine oil indicators
![]() Drives: 2011 Vistory Red 1LS Join Date: May 2018
You keep asking about a low oil level indicator. What does it matter? It is a simple act to check the oil once a week when the car has not been running. I check mine every Saturday morning before I start the car to go into town.
Mine is a 2011 LLT with 70,500 miles on it. I have ~2500 miles on the last oil change. I am setting at about a 1/2 quart or less low (still well within the safe zone on the dipstick) and wont add anything until my next oil change in 500 miles.
The Original Farm Rat
2011 1LS M6 Victory Red Sold 1967 Coupe Green and White 1969 SS 396 Hugger Orange 1969 Z/28 All original White with deluxe interior 1970 RS Blue 1978 Coupe Fugly Green 1978 WS-6 Trans-Am Factory 4 speed 1985 IROC-Z Red |
#6 | |
Yee-aay-ee!
I'll either purchase a 2013 or 2014, depending on which model year has it.
#7 |
I believe it is a force of habit that is not hard to maintain. Plus, I also believe I would rather rely on myself than something mechanical that can fail. On top that I am also a firm believer if you wait until that warning comes on to check/add oil you quite possibly have already done damage. To further add, what happens if you are out in the middle of nowhere and it comes on? Guess you need to carry a couple of quarts in the trunk at all times.
#8 | |
Yee-aay-ee!
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
My 2013 does have it. But honestly, if you see that light, damage could be done. The dipstick is good for up to 1qt low, the low oil light comes on at 2 quarts low, and you never want to be that low.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
#10 | |
Yee-aay-ee!
![]() I'm understanding that these engines simply use more oil than average, right?
#11 | |
On this same line. Do you wait to check your coolant levels until you get an overheating warning?
#12 | |
Here's the rub. In the old days if you ran the motor with the oil low enough and long enough you would probably spin a bearing. The lifters would start rattling long before that. These new V6's are a completely different animal and they rely on oil in more places (double timing chains, double cams etc) so it is more critical to keep an eye on them. Again, it's not like it is running straight through them. Incidentally, I had an 85 Buick Regal with a 6 in it (different motor). I was not big on checking oil, then one day the low oil light came on and in a block, the motor locked up.
#13 | |
Yee-aay-ee!
#14 | |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
Funny you should say that, I DO carry an extra quart of oil with me, ever since the 'low oil' flashed at me once. My car, at 80,000 miles tends to go through a quart at 5,000 miles/oil change cycle.
Don M
Supercharged LGX + 6 speed manual = FUN!! |
