Old 07-02-2018, 03:08 PM   #1
scotty9794
Drives: 2011 ss/rs
Pretty excited to have my car working soon.
I bought my '11 from a friend after it had a fuel fire and was inoperable. Its been sitting in the corner of my garage for almost 2 years now, but this week it goes to a local shop, LSX automotive and performance, and hopefully they can finish it for me in time for Ice Cream Cruise '18. It has a Thompson forged short block, AGP kit with s256 turbos, alky meth system, jakes st4 4l80e, DSS driveshaft, fore triple pump system, and a handful of BMR parts in the rear end for hop control.
I have only ever ridden in the car, and havent driven it yet, so im pretty excited to be able to do it finally. Fingers crossed theres no nasty surprises beyond whats visable. The fire took out the PCM of NC swap harness, engine harness, trans cooler lines, intake manifold, 2 fuel injectors, boost solenoid, Fuel press sender, oil sender, but no damage to any exterior surfaces thankfully. It was $$ to buy the parts, but for what i spent on the car, im still in it for pennies on the dollar.
scotty9794 is offline   Reply With Quote
Old 07-02-2018, 04:21 PM   #2
Splat
Splat's Avatar
Drives: 2012 1SS M6 IOM
Nice
Do you remember the Hp numbers?
2012 1SS Camaro LS3 Inferno Orange
Mods: LSA Supercharger, 2.55 Pulley, Custom Boost Cam, ARH LTH 1 7/8, HFC, 3' Magnaflow Exhaust, JLT CAI, Elite CC V2, BO White Stage 2 TB, GM 3.91 Gears, DSS CF Driveshaft, BMR Bushing Kit.... . Tuned by JTM Motorsports 540 Hp 550Tq on 9PSI
Axles, Monster Clutch, Hotchkis TVS Track Pack kit.......For 2018.
Splat is offline   Reply With Quote
Old 07-02-2018, 06:03 PM   #3
scotty9794
Drives: 2011 ss/rs
Originally Posted by Splat View Post
Nice
It made 889hp/887lbft at 18lbs on e85.
Old 07-05-2018, 06:32 PM   #4
scotty9794
Drives: 2011 ss/rs
And so it begins
Old 07-05-2018, 07:31 PM   #5
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
What caused the fire???????
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned|
God is too good! I don't deserve it, but I sure will accept it!!!
ZX1truth is offline   Reply With Quote
Old 07-05-2018, 08:14 PM   #6
scotty9794
Drives: 2011 ss/rs
The passenger fuel rail return hose ruptured right over the exhaust.
Old 07-06-2018, 09:15 AM   #7
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
Gonna need to hook that monster to the ground. What kind of wheel/tire upgrade are you planning?
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
Taylortoons is offline   Reply With Quote
Old 07-06-2018, 09:54 AM   #8
scotty9794
Drives: 2011 ss/rs
Right now its just getting some 275 nitto 555r on the rears. I want to go to either a zl1 setup, or a 20"/17" setup in the future. My budget wont allow for it right now. It had a 17" set of weld rts wheels on it before, but i didnt get them with the car. The tires on it are the originals @ 26k miles but the rears are destroyed, unsurprisingly. If i have enough left to change out the fronts to nittos or something like that i will.
Old 07-06-2018, 10:00 AM   #9
scotty9794
Drives: 2011 ss/rs
Old 07-06-2018, 04:16 PM   #10
blake-b
blake-b's Avatar
Drives: 2009 ZR1
You won't get traction with the NT555Rs. I recommend MT Street SS or MT Street Rs. I couldn't get traction with Nitto NT05Rs. The MTs are way stickier.
Old 07-06-2018, 06:36 PM   #11
eLeSthree
Drives: 2011 Camaro SS 6sp
Woooo thats gonna be fun. I hope you don't suffer from melted wiring harness nightmares.
That thing will be a beast for sure if you get it lined out.
Good luck bud.
If you have to run the stock size rim (i am) I'd definitely go with a MT ET Street 2. You'll get better mileage from the 555r, but those mickeys are stickies.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 07-06-2018, 11:26 PM   #12
scotty9794
Drives: 2011 ss/rs
Good luck bud.
Ill have to shop around on the MT radials i guess. I was willing to compromise a little for cost, but if the nittos are as bad as you guys are saying its not worth the savings. So far there appear to be no issues electronically. The ECM harness only took some damage on the fuel injector leg. Id rather replace the whole harness than repair the insulation. Trans harness was utterly destroyed, so i got a new one already, and itll go on after the tranny is overhauled.
Old 07-11-2018, 09:00 PM   #13
scotty9794
Drives: 2011 ss/rs
Stopped to check on progress today. Got some good news and bad. Torque convertor took a lot of heat and only had like a quart of fluid in it, all brown. So its going back to circle d for rebuild. Tranny was gonna rebuild as a precaution, but after seeing it pulled out, it will be absolutely necessary. Good news was that major disassembly is done. Flex plates gonna get ARP bolts intsead of OEM bolts and a new rear main seal just in case. Injectors are on the way to FIC for 2 new ones, and then flowmatch and clean em all. Gonna need gobs of new hose but it should start going back together soon.
Old 07-12-2018, 11:42 AM   #14
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
Who will be doing your tuning after that? I use Chad at the Shop Inc in Lincoln. Will be nice to see this around.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
Bildo is offline   Reply With Quote
