Old 07-04-2018, 10:08 AM   #1
Trike rider
Drives: 2014 ss 1Le
A little help
Hello happy 4th everyone. I am a memeber of the international roll racing association. I need to get some mph out of my car I’m second in points but I get I’m loosing to about 6mph. Traction is part of the problem but we start from 30mph so that I can work on with controlling the long pedal some. What would be the first thing I should do to improve her. It is bone stock and power adders are not allowed in my all motor class.
Trike rider is offline   Reply With Quote
Old 07-04-2018, 12:19 PM   #2
Matt8892(2)
Drives: Black camaro 2ss 45th
Cam and heads and air intake considered power adders?
Matt8892(2) is offline   Reply With Quote
Old 07-04-2018, 02:03 PM   #3
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Solid subframe bushings, trailing arms and toe links. Helps with better traction and eliminate wheel hop
Old 07-04-2018, 04:06 PM   #4
Shutudwn
Drives: 2004 Ford Mustang Cobra
Remove some weight.
Shutudwn is offline   Reply With Quote
Old 07-05-2018, 07:02 AM   #5
Powered1le
Powered1le's Avatar
Drives: 2014 2ss 1le
What kind of tires are you running
2014 camaro 2ss/rs 1le [muffler & resonator delete, x-pipe , roto fab cai, 305 35 r20 rear tire 285 35 r20 front goodyear f1 supercar,1 7/8" tsp long tube headers with high flow cats, tsp Prc heads, K1 rods, Wisco pistons, 522whp 495tq, dynojet, btr stage3 cam kit, arp head studs and arp bolts.
Powered1le is offline   Reply With Quote
Old 07-07-2018, 09:25 PM   #6
CrazyRED
CrazyRED's Avatar
Drives: 2014 2SS RS 1LE
NT05's. There's no way you'll haze those tires on stock power at 30mph.
CrazyRED is offline   Reply With Quote
Old 07-08-2018, 11:41 AM   #7
ecreps
Drives: 2014 1LE, 1996 z28
remove weight.
Skinnies up front.
are you allowed a tune?
ecreps is offline   Reply With Quote
