Old 07-08-2018, 10:37 AM   #1
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Any benefit for GPI Rod Mod intake on FBO L99?
Hey guys,
So I'm running FBOs right now on my L99, but I was wondering if adding a GPI Rod modded intake would be worth it. From what I'm seeing many who are running cams do the intake mod, but I'm not sure if it would be worth it otherwise.
Thoughts?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 07-08-2018, 11:55 AM   #2
hammdo
'It's an experiment'
I did it on mine when I was full boltons. If you’ve done everything else, this is the next step...
-Don
Old 07-08-2018, 12:20 PM   #3
sinisterlsx510
sinisterlsx510's Avatar
Drives: 14 ss camaro summit white
From what i heard it will probably net u around 10hp.. many say this is the way to go.. rather than a fast manifold...
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe
2019 sierra duramax 2500 all terrain x
2001 trans am
Lsx 408 ci rebuild in progress(dead project)
1967 camaro
Sbc 327.
sinisterlsx510 is offline   Reply With Quote
Old 07-08-2018, 12:42 PM   #4
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
I would do the ported rod mod, and port the heads while at it.
Apex VS-5RS Forged Wheels,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 103mm TB, Dr Phil Tune,Borla Atak...955rwhp/967rwtq
gm2376 is offline   Reply With Quote
Old 07-08-2018, 09:56 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I talked to the guys at Camaro Fest last year and they said unless you have supporting parts it's not really worth doing for a stocker, but if you find a good deal on one and plan on doing a cam and heads it'll be well worth it then. I was set to buy one till they told me that.
Orange Krush II
Old 07-08-2018, 10:01 PM   #6
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
In the end it all adds up!
zz430camaro is offline   Reply With Quote
Old 07-09-2018, 09:49 AM   #7
xc_SS/RS
Drives: 2010 Camaro SS/RS
lol what? did they at least tell you the supporting mods 'needed' to run a ported/modified stock intake manifold? i've got one with stock internals and felt a performance increase
OP do it man! you'll see gains on an engine with stock internals for sure. i've got one and it works
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 07-09-2018, 12:41 PM   #8
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Im full bolt on but dont have all the bolt ons....... What all do you have? Headers, CAI and exhaust im suspecting? Yes a rod mod intake is worth it.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 07-09-2018, 04:32 PM   #9
62nalide
62nalide's Avatar
Drives: 2013 SS
FBO's and a GPI rod mod is worth it 100% You will see gains all the way across!
62nalide is offline   Reply With Quote
Old 07-09-2018, 08:16 PM   #10
LCPLPunk
USA-1
LCPLPunk's Avatar
- Running mods in sig!
Old 07-10-2018, 08:59 AM   #11
xc_SS/RS
2010 2SS/RS
Old 07-10-2018, 07:30 PM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
OK guys, so I haven't seen this term used before,, gonna bite, what is FBO's ?? lol. Thanks. I know what all the rest is about.
Old 07-10-2018, 07:41 PM   #13
LCPLPunk
USA-1
LCPLPunk's Avatar
Full Bolt Ons.
Old 07-11-2018, 07:33 AM   #14
lazerlemonta
Drives: 2010 C6 1LT
FBO for most is headers and a cold air intake LOL no where near what full bolt on is. They need to start using LBO low bolt ons
Best MPH 134.82
