Old 07-12-2018, 11:20 PM   #1
SSlow1
Drives: 2014 Camaro SS
MM catch can with AGP tt
I bought a used agp tt kit with a mm catch can but have a few questions. How are you running your catch can with FI? How did you tap and drill the valve cover for the oil return line and what did you do with the evap bc I pulled one of the vacuum lines from the intake for wg. I don't think my mm catch can has the check valve. Here are some pictures so please help me out. Thanks
SSlow1 is offline   Reply With Quote
Old 07-13-2018, 12:02 AM   #2
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
This is what I got from David at MM when I asked him about the “Wild” catch can.
“the link below has another link to the full install document as well as hose routing diagram.
the only change for the turbo kit is you will have to decide if to route the pcv air supply to one / both turbo filters, or substitute a separate air filter.
the dirty side discharge will always come out the oil fill adapter, and the pcv valve from the can always connects to intake manifold vac.”
https://docs.google.com/document/d/1...6M/mobilebasic
760bowtie is offline   Reply With Quote
Old 07-13-2018, 07:15 AM   #3
scotty9794
Drives: 2011 ss/rs
I had the same question a couple weeks ago
scotty9794 is offline   Reply With Quote
Old 07-13-2018, 06:02 PM   #4
SSlow1
Thanks for all the help. Now I have to get a 1/4npt tap and -6an fitting. Would yall trust this feed line. The guy I got it from said it was like that when he bought it.
Old 07-13-2018, 07:54 PM   #5
NABeastRR
NABeastRR's Avatar
Drives: Camaro
My line does not look like that! The drivers side valve cover he told me to just put a small breather on it as I did not run it to the filter/s. The oil cap hose runs to the can and then into the side nipple of the intake manifold.
15 Camaro 2SS/RS
13.3@106 100% stock
12.0@114 VR-DRX/RCR manifold/BW stg2 TB/2"ARH w cats/3"Corsa extreme/Fasterproms tune/MT Street R
AGP TT build in progress
NABeastRR is offline   Reply With Quote
Old 07-14-2018, 12:01 PM   #6
SSlow1
Ok I bought a 1/4" tap and a have a 7/16 drill bit. Is it supposed to be a 5/16 drill bit or did I buy the wrong tap
Old 07-14-2018, 12:53 PM   #7
760bowtie
760bowtie's Avatar
That’s right, that’s what AGP sends with their kit. 7/16 bit and 1/4-18NPT tap
Old 07-14-2018, 06:15 PM   #8
SSlow1
Ok I bought the wrong one the first time but got the right one. Thanks for all the help.
Old 07-14-2018, 06:43 PM   #9
SSlow1
On the -6AN fitting is it a -6an/-6an or -6an/ 1/4npt
Old 07-14-2018, 08:22 PM   #10
760bowtie
760bowtie's Avatar
I believe that’s -6AN to 1/4NPT but don’t quote me on that. I can email you the install instructions if you don’t have them.
Old 07-14-2018, 09:02 PM   #11
AGP Turbo
Drives: All things Turbocharged
It is.
AGP Turbo is offline   Reply With Quote
Old 07-14-2018, 10:16 PM   #12
SSlow1
Thanks again guys. AGP Turbo I need the small oil line to the turbo. I will message you for a price.
