![]() Drives: LS3 e46 M3 Join Date: Nov 2011
LSx Dry Sump Setup (Dailey Engineering / Peterson Fluid Systems)
LSx Dry Sump Setup $4500 + Shipping. (UPS Domestic / DHL International)
Dailey Engineering 3 Stage Dry Sump Pump (Fresh from service at Dailey Engineering, 0 hours) Pump Mounts directly to the billet pan, no need for scavenge lines to the pump. Dailey Engineering 3 Stage Billet Aluminum LS Dry Sump Pan w/ Two Brand New Drive Belts GST Low Friction PTFE LS Rear Main Seal (Brand New) Aluminum Breather tank with AN-16 Male Fitting w/ -Aeroquip AN-16 120 Degree -Aeroquip AN-16 45 Degree -Aeroquip AN-16 Stainless Hose Steel AN-10 to LS Oil Galley (Short) Aluminum AN-10 to LS Oil Galley (Long) LS3 Valve Cover w/ AN-12 Welded Fitting for Peterson Crankcase Vacuum Regulator Peterson Fluid Systems Crankcase Vacuum Regulator 08-0455 Peterson Fluid Systems 08-0010 - 3 Gallon Oil Tank Dual Scavenge Inlet w/ -Aeroquip FBM2170 - Aeroquip Reducers Fitting, Union Reducer, Male -16 AN to Male -12 AN, Aluminum, Blue -Aeroquip FBM2170 - Aeroquip Reducers Fitting, Union Reducer, Male -16 AN to Male -12 AN, Aluminum, Blue -Aeroquip FBM2170 - Aeroquip Reducers Fitting, Union Reducer, Male -16 AN to Male -12 AN, Aluminum, Blue -Peterson Fluid Systems 08-0101 Dry Sump Oil Tank Mounting Bracket -Peterson Fluid Systems 08-0101 Dry Sump Oil Tank Mounting Bracket Peterson Fluid Systems 09-0452 - 60 Micron Oil/Fuel Filter with Bypass -12AN Fittings w/ -Peterson Fluid Systems 09-0400-027 End Cap Inlet -12 W/-10 w/ 1/8NPT PortT -RaceGrade 1/8NPT Liquid Temp Sensor M 25-2197 -Aeroquip AN-10 Straight -Aeroquip AN-10 120 Degree -Aeroquip AN-10 Stainless Hose XRP Inline Oil Filter Housing with Wiggins -16 Connections ARP 234-2504 - LS7/LS3 Dry Sump 12PT Balancer Bolt Kit ATI Super Damper Serpentine Series Harmonic Balancers 917279 w/ Dry Sump Drive Gear Inner Hub You need -16 lines to hook this up depending on where you mount the tank. I can provide you with AN fittings or Wiggins clamps depending on how you want to install this. |
Bump.
Bump
Man this is such a cool system!!
Orange Krush II
Bump.
#6 |
Bump.
#7 |
![]() Drives: 2015 2SS/RS 1LE (Red Hot) Join Date: Apr 2016
still available ?
#8 |
#9 |
Bump, for those of you making offers the total cost on this system was $6800+, a $2000 offer isn't going to cut it.
