Old 11-23-2009, 09:37 AM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
Anyone remove mufflers & resonators on LS3?
Anyone removed their resonators along with the mufflers on an LS3? If so, does it still sound okay? Is it too loud? Any sound clips by chance?
I'm thinking about doing a muffler delete along with an x-pipe and I'm not sure if I should leave or remove the resonators?
Build Journal
Old 11-23-2009, 10:10 AM   #2
FFPM73
Firefighter/Paramedic
FFPM73's Avatar
Drives: RJT 2SS/RS M6 LS-3
I don't have a sound clip, but I did a muffler delete with a magnaflow "X" pipe installed before I spent thousands of dollars on a cat-back system for a sound I may or may not like. The total cost for everything was $140.00 and the sound is awesome. I have been told by a buddy of mine that works at Chevrolet that the LS-3 comes with high flow cats from the factory. Do the muffler delete and have them take out the "H" pipe and add the "X" pipe, you won't be disappointed. Let me know what you decide.
FFPM73
FFPM73 is offline   Reply With Quote
Old 11-23-2009, 10:28 AM   #3
Edrock
Edrock's Avatar
Drives: '10 Camaro 2SS LS3
I did something similar to what FFPM73 described except I took out the resonators and and added Flowmaster mufflers. I did this for 2 reasons: 1) I wanted to hear the exhaust in the cabin, hence removed the resonators. 2) I was afraid the exhaust was going to be too loud and also wanted to shape the exhaust note a bit so opted for the Super-44s. You may want to check with your local shop about the legality of doing a muffler delete. I had one shop here tell me it would flunk inspection because mufflers of some sort were mandatory. Good luck.
DT Shorties, Solo hi-flow Cats, X-pipe, resonator delete, Flowmaster Super-44s, VMAX TB, Stronger MAF, C.A.I. Intake with race scoop, and JRE Tune!
WOT is my happy place!!
Edrock is offline   Reply With Quote
Old 11-23-2009, 12:05 PM   #4
caverman
caverman's Avatar
Man....wish I could find that setup for $140. I've been quoted $350 for that setup. $140 would be a no brainer. Not much lost if you didn't like the setup.
So you didn't remove the resonators?
I'm wondering if I should spend another $200 and add SLP LM II mufflers to the setup? My concern on that is that the stock system is T-409 and the mufflers are T-304. Not sure the different metals will work together. I've always used Flowmasters in the past but I'm not liking the looks of the square muffler on the Camaro over the round ones like SLP has. Plus...I like the sound of the LM II setup.
I'll talk a little with the guy I was recommended to but I could probably go without the mufflers first and worst case add them later.
Build Journal
Old 11-26-2009, 01:49 PM   #5
2010SSRS
2010SSRS's Avatar
Drives: 2000 Silverado
my exhaust guy charged $80 for muffler delete only. sounds much better, but a bit loud for the wifes taste.
and the deceleration pop is redneckish......
i'm gonna throw long tube headers and complete Corsa on it. mainly for HP and future bolt ons.
IOM 2SSRS LS3 R6P - VIN 7553 Delivered 5/22/2009 Kooks, Corsa and Roto-Fab - SOLD 9/2010
VR 2SSRS LS3 - Borla, SLP CAI
2010SSRS is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
Swapping LS3 Mufflers onto an L99 Car? Hicompression Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 08-14-2009 10:53 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
