Old 07-18-2018, 09:51 AM   #1
ViperV12
Peacemaker
Drives: 2010 Camaro IOM 2SS/RS
Source for 5/16" Vacuum Lines
Trying to determine what they used on the SS as vacuum lines. I want to move the purge valve off of the front of the passenger side cylinder head to under the fuse box and need to extend the 5/16" lines. If anyone knows what the lines are made of and/or where I can purchase some it would be appreciated.
ViperV12 is offline   Reply With Quote
Old 07-18-2018, 10:35 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Any good auto parts store.
Orange Krush II
