Old 07-19-2018, 08:15 PM   #1
scotty9794
Drives: 2011 ss/rs
A/C drain grommet
Discovered while have my car repaired after a fluid fire that the drain grommet for the a/c system was damaged. Ive ordered a new one based off a parts drawing. I cant find much info about the drain, other than this grommet is supposed to empty the water, is there anything else in there to consider beyond grommet replacement?
TMS forged 376, 237/239 cam, AGP kit w/ s256 twins and race intercooler, Alky dual nozzle meth system, FIC 127lb injectors, Fore dual TI 450s, Jakes stage 4 4l80e, Circle D triple disc billet 3400 stall, DSS aluminum shaft, eBoost 2 controller, BMR toe rods-adj lower control arms-adj trailing rods, and bushings, nt555r rears.
scotty9794 is offline   Reply With Quote
Old 07-20-2018, 07:22 PM   #2
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
It's just a drain from the HVAC setup. Your evap core naturally makes moisture and it drains through that grommet/drain. You'll be fine just to replace it.
JerTM is offline   Reply With Quote
Old 07-20-2018, 09:27 PM   #3
scotty9794
Drives: 2011 ss/rs
I get the process, but was concerned there was more to the drain than just the grommet. I feel better knowing its just the grommet now. Thanks a bunch
Old 07-21-2018, 09:54 AM   #4
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
So does water just drain thru a hole in the grommet? If so what does the water drip on?
camguynj is offline   Reply With Quote
Old 07-21-2018, 01:23 PM   #5
scotty9794
Drives: 2011 ss/rs
Transmission presumably
Old 07-21-2018, 03:24 PM   #6
JerTM
JerTM's Avatar
Pretty much. As long as it's out of the airbox for the hvac it doesn't matter. I have repaired a truck that had the tube on upside down. Once there was enough water in the airbox it started to blow a mist out of the vents. I turned the drain right side down and about a gallon of water came out haha.
Old 07-21-2018, 06:47 PM   #7
CrazyRED
CrazyRED's Avatar
Drives: 2014 2SS RS 1LE
After a warranty repair on my '14 SS the dealer did not hook up the drain right and it was a lot more than mist coming out of the vents.
CrazyRED is offline   Reply With Quote
Old 07-21-2018, 09:31 PM   #8
camguynj
camguynj's Avatar
Holy Sh*T Was anything ruined? What did they do for you?
Old 07-22-2018, 11:34 AM   #9
JerTM
JerTM's Avatar
Must have turned on your interior rain feature haha. Looks like a shorter box in the Camaro would let the fan blow out more than a mist.
Old 07-22-2018, 04:19 PM   #10
CrazyRED
CrazyRED's Avatar
I think there may be a post on here about my horrible experience with this dealer, but this happened after several mess ups on their part.
I was mad as hell when I turned on the car and this started happening.
I guess my whole point is don't skimp on the AC drain unless you want a cold shower.
Old 07-22-2018, 06:15 PM   #11
scotty9794
Drives: 2011 ss/rs
Definitely hoping it arrives before my torque convertor does so theres no more time lost on my reassembly. Glad its just the grommet part to replace
