Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Suspension / Chassis / Brakes
Old 07-21-2018, 10:30 PM   #1
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
adm solid cradle bushings, toe rods, trailing arms and more
sold
ttshovel is offline   Reply With Quote
Old 07-22-2018, 12:07 AM   #2
TheInfamouSS
@LS.ACE
TheInfamouSS's Avatar
Drives: 2014 Chevy Camaro 2SS/1LE
if you decide to split up the suspension I will buy the non adjustable trailing arms. I would buy the upper control arm mounts too, but they are red. I want it to look as stockish as possible back there.
If you are willing to do it, just pm me and send me some pictures so I know what they look like and what condition they are in. It's easier for me to see when someone PMs me while im working since it goes to my e-mail. PayPal ready.
Some weird snail with a belt on it | Tial Q Bov | CCP Jam Cam | Stainless Works 1 7/8" Headers to Custom 3" Exhaust | Alky Control Dual Nozzle| ProMeth Trunk Mount Tank | Melling Oil Pump | DSX Aux Pump | id1050x Injectors | McLeod RXT w/ Monster Billet Release Bearing | ZL1 3.73 Rear Diff | BMR Delrin/Poly Diff Bushings | DSS 1-Piece Aluminum Driveshaft | ZL1 Axles | Metco Driveshaft Loop | BMR Adjustable LCA's, TA's, Toe Rods | BMR Adjustable Sway Bar w/ Fe3 End Links | Mickey Thompson 305/35-20 Street S/S Drag Radials |
TheInfamouSS is offline   Reply With Quote
Old 07-27-2018, 07:26 PM   #3
Arkangel-77
Arkangel-77's Avatar
Drives: 2010 SS Camaro
if U want to sell Just the adm solid cradle bushings - let me know, Thanks
Arkangel-77 is offline   Reply With Quote
Old 08-02-2018, 11:56 PM   #4
GRNFLSH
GRNFLSH's Avatar
Drives: 2015 Camaro 2SS Green Flash Edition
Pm sent
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo
GPI VVT SS1 cam and CNC ported heads milled .30
BTR .660 springs, Straub solid bushing trunions
GPI rod-mod intake with I-M heat sheild
Circle D 258mm Pro single disc 3700 rpm stall converter
169F thermostat & manual fan switch
Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft
GRNFLSH is offline   Reply With Quote
Old 08-07-2018, 08:39 PM   #5
Baddbird
Baddbird's Avatar
Drives: 2014 2SS
payment sent.
Baddbird is offline   Reply With Quote
