Old 07-23-2018, 10:57 AM   #1
hou30guy
Drives: 2011 convertible 2ss/rs
2011 ss convertible 408 stroker supercharged
Ok im supercharged currently at 600whp turning it up to 775-800whp soon, i have the stock 3.27 gears never had a problem, but trying to see if i should keep them or go 3.45 or 3.73 since the convertibles are heavier. Im in Houston where the land is flat and my weight with the iron block, maggie supercharger and my mechanic tools in the trunk im probably at 4500 to 4650lbs. It also has circle d 3200 stall too. 20s front and 18 rear drag pack with 305/45/18.I dont track or drag it, its my dd but i do light to light and fwy pulls occasionally.
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 07-27-2018, 12:45 PM   #2
RedRyder
RedRyder's Avatar
Drives: 2010 VR 2SS/RS M6 Camaro
I'm interested in opinions on this. I'm ~800rwhp and will be 900 in the future with stock 3.45 but I'm an M6 coupe. I'm going to a ZL1 rear and need to do 3.23 or 3.73...
I think 3.45 is just right at this level but I need a beefier non-costly rear end.
RedRyder is offline   Reply With Quote
Old 07-27-2018, 01:07 PM   #3
1911 1LE
Drives: 2015 SW 2SS 1LE
I had the ZL1 3.73s and switched to the 3.23s for running the Texas Mile. The 3.73s are better for the street
Maggie 2650 @ 18psi/ 75mm 10 rib/ Dual alky nozzles/ Roto-fab/ ARH 2" Lt's/ GT-12 cam/ ZL1 3.23 Conv./MGW/RPS triple carbon clutch/RSG tranny upgrage/Pedders Ex. XA w/ remote cans and a lot of other crap 897/8??@tires
1911 1LE is online now   Reply With Quote
Old 07-27-2018, 06:26 PM   #4
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
Do the math and you’ll find the answer that fits your combo...
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
