Old 07-24-2018, 07:50 AM   #1
Zslash28
Jumanji
Zslash28's Avatar
Drives: '14 Z/28 - AGM - No A/C
Official - Z/28s w/Bad Valves or Dropped Valves
Seems to be alot of concerns regarding the LS7 head issue and our Z/28s. I would like this thread to be where we capture only those cars that have had one of the following;
1. Any failed factory installed LS7 engine.
2. Any dropped valve resulting in GM repair.
3. Any car that had heads replaced,
and the heads failed valve inspection.
Please provide info as to what led to the failure if known. If the failure mode is unknown, please state so.
Also, for the sake of keeping this on topic, only post info on known failed Z/28 LS7s, or Z/28 heads that failed valve inspection. I dont care about the Corvettes, or "maybe, might, could" assumptions on the Z/28 LS7 heads being suspect. Lets stick to facts, and real events, not 2nd or 3rd hand stories.
Keeper of the 5th Gen Z/28 Registry.
Registry Facebook.
Follow: @5th_gen_z28_registry
I track wrecked Z/28s Total lost -41
Zslash28 is offline   Reply With Quote
Old 07-24-2018, 10:11 AM   #2
2013blackgt
Drives: Sedan
I had Katech install their stage 2 LS7 package on my z/28 and they said my valve guides were out of spec. I don't have the numbers though, they never gave them to me. Fyi, my car had 7,800 miles on it when they did the work.
2013blackgt is offline   Reply With Quote
Old 07-24-2018, 10:29 AM   #3
Zslash28
Jumanji
Zslash28's Avatar
Excellent info, thank you for sharing. I wonder if they kept record of the valve specs after they did your work.
Registry Facebook.
Old 07-24-2018, 11:06 AM   #4
2013blackgt
Drives: Sedan
They do.
Old 07-24-2018, 11:35 AM   #5
Mark_Z28
Drives: Black 2015 Z28 #457
That's funny considering they are the reason the original valve guides were out of spec.
Mark_Z28 is offline   Reply With Quote
Old 07-24-2018, 02:08 PM   #6
Nasty Z28
Drives: 2015 Z/28
my car #1019 2015 AGM ac/speakers was a GM buy back car. Had oiling issues. From the info i have the motor was fixed/replaced at 3500ish miles. I bought it with 3600 miles on it and had the heads done almost right away along with a few other things. Car now has 5200 miles on it with no issues.
Nasty Z28 is offline   Reply With Quote
Old 07-24-2018, 08:20 PM   #7
4 FN 27
Drives: 2015 Z28
The story...of Unscheduled High Speed Disassembly...
https://www.camaro5.com/forums/showthread.php?t=419077
Nothing conclusive to say it was the Valve Issue and nothing to say it wasn't.
All I know is my Dealer and GM took care of me 100% with no hassle.
"Resale value is my beneficiaries problem...unless they can bury my in my Z...problem solved."
4 FN 27 is offline   Reply With Quote
Old 04-21-2019, 09:08 PM   #8
JeffInDFW
Camaro owner for 29 years
JeffInDFW's Avatar
Drives: 96 Viper GTS/09 Sky Redline/95 Z28
I'm not being snarky, asking honestly....Can you share why this is the case? My understanding was that Linamar was who produced the LS7 heads, and it was Linamar that had one of their machines set out of spec which polluted the pool of available heads. Thanks for anything you can share.
JeffInDFW is offline   Reply With Quote
