Old 07-24-2018, 11:39 AM   #1
Lacpac
Lacpac's Avatar
Drives: 2012 Crystal Red Tintcoat RS
Replaced Side Badges - Really Like em
Got these mirrored finished stainless badges from emblempros.com
Was worried about making the switch but am so glad I did. Really like them!
Lacpac is offline   Reply With Quote
Old 07-24-2018, 11:43 AM   #2
farm rat
farm rat's Avatar
Drives: 2011 Vistory Red 1LS
How do they mount? I really like them too.
The Original Farm Rat
2011 1LS M6 Victory Red
Sold
1967 Coupe Green and White
1969 SS 396 Hugger Orange
1969 Z/28 All original White with deluxe interior
1970 RS Blue
1978 Coupe Fugly Green
1978 WS-6 Trans-Am Factory 4 speed
1985 IROC-Z Red
farm rat is offline   Reply With Quote
Old 07-24-2018, 11:47 AM   #3
farm rat
farm rat's Avatar
Never mind I answered my own question. They are going to cost me some money.
Sold
1970 RS Blue
1985 IROC-Z Red
Old 07-24-2018, 12:05 PM   #4
Lacpac
Lacpac's Avatar
$55 shipped for two. 3m adhesive tape.
Old 07-26-2018, 03:10 PM   #5
Blubird68
Drives: 1993 z28/2010 2SS
how did you remove the original ones ?
Blubird68 is offline   Reply With Quote
Old 07-27-2018, 10:27 AM   #6
Lacpac
Lacpac's Avatar
Badge removal
There are alot of videos on you tube. I used a heat gun to warm up the old ones to about 90 degrees. Hairdryer works fine too. Don't go over 120 degrees, you just want to the old glue soft. Then I used fishing line and worked it back and forth behind the old emblem. Took less than 5 minutes each. Next, I used Goo Gone Automotive to get the residual glue off with a microfiber and plastic scraper - the kind you use to remove glue when doing Paintless Dent Repair (Not necessary). Just let the goo gone soak in for a few minutes and work it with your finger and microfiber cloth. Took maybe 10 minutes per side. After it's cleaned off you want the surface to be free of any filmy residue so I used McGuires Ultimate Compound which will not scratch the clearcoat. You can use alcohol as well. I found it useful to use blue painters tape across the top of the old emblem before removal so I had a line of reference for applying the new badge. When you put the new badge on make sure you are straight because there is no repositioning. It sticks tight!
