Old 07-26-2018, 10:17 PM   #1
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
"A" Post Gauges
With the difficult time of viewing the oil pressure gauge I am thinking of adding a 2 pod setup at the A post. I have a 2014 2LT/RS convertible. I would like to have an oil pressure gauge as well as the water temp gauge.
Has anyone done this? If so could you post some pictures?
I would really appreciate any pictures you may post of different style gauges.
VR Larry
Deputy347k9 is offline   Reply With Quote
Old 07-30-2018, 01:50 PM   #2
Dragonman
Dragonman's Avatar
Drives: 2015 1LT OBE
While not on the A pillar, there is an A pillar cover out there that will hold 2 gauges. The one that I was eyeballing before I bought the vent pod doesn't appear to have the same texture and color as the OEM cover so I went with the vent pod.
_______-2015 1LT JUSTICE----------------------------------1997 B12-___________
Dragonman is offline   Reply With Quote
Old 07-30-2018, 06:47 PM   #3
private03061
color is close enough. Textures all wrong
private03061 is offline   Reply With Quote
Old 07-30-2018, 08:41 PM   #4
gutterball
gutterball's Avatar
Drives: 2014 1LS M6 Supercharged
Send a message via AIM to gutterball
How about in the 2" strip that runs across the Dash ( one is Volt. the other oil press)Name:  camaro dash.jpg
gutterball is offline   Reply With Quote
Old 07-31-2018, 08:48 AM   #5
Dragonman
Dragonman's Avatar
Originally Posted by gutterball View Post
How about in the 2" strip that runs across the Dash ( one is Volt. the other oil press)Attachment 949545
What I'd really like is for that entire strip to be an LCD/LED display that could be set similar to the aeroforce gauges without the limitation of a cyclic display. Would like that little strip by the driver's door to be the same.
Old 07-31-2018, 03:59 PM   #6
Deputy347k9
Could you tell me more about your setup? Where did you purchase? Difficulty installing? Cost?
Many thanks
Larry
Old 08-05-2018, 06:13 PM   #7
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Nice set up . And what is that display in front of your shifter.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 08-13-2018, 02:39 PM   #8
gtpvette
Drives: 2016 C7
VR Larry
Larry,,, have you gotten anywhere on this?? Looking at a two-in-one Aeroforce for my FR-S LFX swap for oil pressure and water temp. The thing I like is this gauge can show lots of other information as well.
http://www.aeroforcetech.com/contact_us.html
gtpvette is offline   Reply With Quote
