Old 07-27-2018, 12:04 AM   #1
Matt8892(2)
Drives: Black camaro 2ss 45th
What is this piece and does this look like an issue?
I purchased an axle from a forum member because I have a tear in the boot of mine. I received the package today and was looking to do the install tomorrow. There’s a small dent on the metal on the side that does into the diff. I’m not sure if this ring presses against the seal to create a seal. I really don’t want to install this and have any issues. Thanks guys
Matt8892(2) is offline   Reply With Quote
Old 07-27-2018, 12:50 AM   #2
94z28inok
Camaro- Life Member
94z28inok's Avatar
Drives: 15 Camaro 2SS/RS, 19 Tahoe
Send a message via Yahoo to 94z28inok
I would not install that. It spins, meaning its going to wear uneven. If anything were to press to the seal, it would need to be even all the way around.
15 2SS/RS LS3 M6 Summit white
16 200 40mpg Vivid Blue Pearl
19 Tahoe 5.3 Boring Grey
91 Camaro RS 305 TBI 700R4
85 Corvette - TBD
05 Envoy 4.2 4x4
94z28inok is offline   Reply With Quote
Old 07-27-2018, 05:09 AM   #3
T-PWR
Drives: Camaro SS/RS LS3 2013
A couple of gentle hits with a plastic hammer or something similar should fix that.
T-PWR is offline   Reply With Quote
Old 07-27-2018, 07:27 AM   #4
Matt8892(2)
But as I think more about it. That shouldn’t press against the deal. Cause flat or not the seal is stationary. If that were pressed against the seal, it would destroy the seal even if that was flat. It may not touch anything. If that’s the case it should be fine. But I was hoping someone could give a difinitive answer
Old 07-27-2018, 10:07 AM   #5
T-PWR
When itīs not deformated it will not touch the seal but it may do now. But you should be able to fix that like I mentioned before.
Old 07-27-2018, 10:27 AM   #6
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
Tap is flat and install it.
JerTM is offline   Reply With Quote
Old 07-27-2018, 11:22 AM   #7
Matt8892(2)
Yea thanks guys. Few little love taps with a hammer and it’s back to straight. Wouldn’t even be able to tell now that is was ever bent. Should have it installed within an hour hopefully
