Old 08-03-2018, 01:40 AM   #1
KTMracing09
KTMracing09's Avatar
Drives: 2SS/RS L99 ABM
Vvt tuning
Does nobody know how to tune a damn VVT cam? Lmao I’ve had my car two different places, mods in sig. Car made 401/406 at one place, another 406/397 both dynojets. Granted the converter was unlocked. GPI is a long ways away from me for a dyno tune 15+ hours. You think I would be better off letting Ryan remote tune it for me? This is starting to get expensive at $500+ a pop.
Rotofab CAI, 2" LT Headers/non catted, 3" Straight Pipe w/ X-Pipe, Elite Catch Can, GPI SS3 VVT, 9" 4000 Triple Disc, Yella Terra Ultralite Rocker Arms, MSD Super Conductor wires
KTMracing09 is offline   Reply With Quote
Old 08-03-2018, 06:47 AM   #2
GRNFLSH
GRNFLSH's Avatar
Drives: 2015 Camaro 2SS Green Flash Edition
I’m close enough for a dyno tune, but he does remote tunes as well. He’s got tons of experience with VVT. He tuned mine and a friends car, and we’re both very happy with his work.
In person he made at least 6-7 dyno pulls to get the timing and fuel just right before he was happy with it. Then he made another 4-5 pulls on the street for shift points and driveability. I went back for an update after adding a stall converter and repeated the street tune. Keep that in mind as it’ll take a little longer to remote tune as you will need to data log after each tweak and adjustment, load a new file and data log again.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo
GPI VVT SS1 cam and CNC ported heads milled .30
BTR .660 springs, Straub solid bushing trunions
GPI rod-mod intake with I-M heat sheild
Circle D 258mm Pro single disc 3700 rpm stall converter
169F thermostat & manual fan switch
Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft
GRNFLSH is offline   Reply With Quote
Old 08-03-2018, 07:26 AM   #3
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
I'm not sure how close Mechanicsville, MD is to Gettysburg, PA, but Jeremy Formato of Fasterproms is coming up again soon for tuning and he's GREAT with LS engines. I'm considering driving back to PA for him to retune my car when I install my VVT cam. Checkout http://fasterproms.net/ to get in touch with him.
Check out my build thread
Old 08-03-2018, 09:00 AM   #4
John_C
LSx FTW!!!
Drives: 2010 Camaro 2SS RS
Good luck.
I paid a guy $500 and he did a MAF only tune. No trans tuning and no VVE. Cold starts crank too long. Until warm it surges and stalls a lot.
Been trying for 3 months to tune it myself with help from YouTube and a buddy.
It’s a lot better now, but still not tuned VVE, cold start, etc., yet.
John_C is offline   Reply With Quote
Old 08-03-2018, 10:04 AM   #5
Jason 98 TA
Drives: Camaro
Texas Speed camshafts come with a VVT table so you don't have to make adjustments to it. If that is a TSP cam shoot me a PM and I'll get you a vvt table we developed off the engine dyno!
Jason
Jason 98 TA is offline   Reply With Quote
Old 08-03-2018, 05:14 PM   #6
KTMracing09
This is what I found about him
Old 08-03-2018, 05:17 PM   #7
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Um, DynoSteve charges $370 for the tuner and tunes for life...
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 08-03-2018, 05:17 PM   #8
KTMracing09
Originally Posted by John_C View Post
Good luck.
The car runs good and smooth, it’s just definitely lacking in the power department from others I’ve seen on here. Im talking like -40 -50 whp
Old 08-03-2018, 08:39 PM   #9
pyroguy
pyroguy's Avatar
Drives: ABM #832
Not sure what was going on there, but I've seen him work wonders on a number of cars including mine.
Old 08-03-2018, 10:09 PM   #10
RedTexasSS
Drives: 2012 SS Red w/ black rally stripes
Ryan remote tuned mine when I installed the camshaft and remote tuned it a second time when I installed the supercharger. He does an awesome job, I'm very pleased.
2012 SS Camaro, Victory Red w/black rally stripes, SLP front splitter, ZL1 Rocker panels, ZL1 Add-ons Stealth Wickerbill, L99, Magnuson Heartbeat supercharger, 65 lb. injectors, 87 mm pulley, ZL1 fuel pump, ADM FPCM,1 7/8 Texas Speed long tube headers, v-max ported throttle body, Rotofab cold air intake with Apex scoop, Apex catch can, MSD plug wires, AEM AFR and Boost gauges, GPI SS1 VVT Cam, HP tuners with remote tune by Ryan at GPI, Solo axleback exhaust w/j pipes and stock resonator.
RedTexasSS is offline   Reply With Quote
Old 08-04-2018, 03:58 PM   #11
John_C
LSx FTW!!!
I know exactly what you're talking about. Mine was not strong until me and my buddy started working on the tune.
There was a lot to do on the trans tuning. It was flaring a lot on upshifts and shifting slow. It was losing a lot of ET and power on that alone.
Then he had too much timing in some areas creating knock retard and not enough in others. That was losing us some power.
It still has issues. After about 5,600 rpm's, the power dips off, but the cam is good to 6,600 (it'll make power to 6,800 via TSP's own dyno videos).
My friend thinks that's due to the expected torq and VE being out of whack. He says when all that goes wonky, the car will actually start to shut the throttle body. That would explain why my dyno graph dips down at 5,600 rpm's.
I just can't seem to fail the MAF and get a good log to tune VVE because it keeps going in to reduced power mode. When it does that, it barely moves under its own power. Not fun when it happens pulling out in traffic or on the freeway at 70 mph.
Dyno operator left off early and did not log tq for some reason. But here is my dyno pulls....
TSP VVT 3.2 cam dyno at flywheel is 2nd picture. Note where power maxes out. Based on that, my guess is I should be near 500 whp peak because I have heads, too....
Old 08-04-2018, 05:39 PM   #12
GPI Aaron
GPI Aaron's Avatar
Drives: 2008 Z06
Here is a link to our VVT tables published on our site.
https://gwatneyperformance.com/wp-co...ttings-L99.pdf
GPI Aaron is offline   Reply With Quote
Old 08-06-2018, 06:45 PM   #13
punk5150
punk5150's Avatar
Drives: 2014 SS/RS CRT
Stop wasting time and go through GPI and have them tune it. Ryan will do you right. They made the cam and know what they are doing.
punk5150 is offline   Reply With Quote
Old 12-28-2022, 06:36 PM   #14
crank383
Drives: 2014 Camaro SS L99
I'm wondering if I need a phaser limiter for my cam install? It is .500 stock lift but longer duration at mid 220's @50. The stock can is 197/201@50
crank383 is offline   Reply With Quote
