Old 08-03-2018, 10:58 AM   #1
mov
mov's Avatar
Drives: 2011 Chevy Camaro SS
2011 SLP 2SS/RS Camaro ZLX-1 of 1 CMS Build Show & Go Car
I’m selling my 2011 SLP 2SS/RS Camaro ZLX-1 of 1 CMS Build, Show & Go Car with Supercharged 6 speed manual transmission. This is the first Camaro I've ever own and still in learning mode about the car. For those of you who have been long-time members of this forum you might have come across the complete build by the original owner. Every question you have about this car can certainly be answered via his threads located here so please check it out:
https://www.camaro5.com/forums/showthread.php?t=187393
The car was ordered as a fully loaded 2SS/RS in October 2011 from Paso Robles Chevrolet. In the meantime, the 1st owner was working closely with the West Coast head honcho of SLP to have the SLP TVS 2300 Supercharger, Loud Mouth II Exhaust & X-Pipe ready while they found the car.
Cunningham Motorsports performed the full build from the ground up. Rear Wheel HP goal was 650-700 safely, and to do so almost every stock piece had to be swapped out. This was the first SLP (Street Legal Performance) Camaro built in California and the build took roughly 13 months to complete.
The car is very clean, excellent condition, garage kept and never driven in the rain or any inclement weather conditions. The car has low miles for its age but is still being driven “very little” but mainly to car shows, so miles could be a little different if purchased.
The car has been featured in GM High Tech Performance Magazine (April 2013 issue), Camaro Performers Magazine (May 2013 Issue) and was selected out of over 5000 cars to be featured on display indoors at the GM Nationals in Carlisle, Pa with 30 other cars representing different eras. The car also won 1st place two years in a row at the Super Chevy Show.
This Camaro is indeed a real head turner and always captures everyone’s attention. As mentioned, the car was fully rebuilt from the ground up, and rebranded the “ZLX” by its original owner and creator of this beast, John Couf. There are approximately 80k+ in parts and labor for the mods alone. The car is making 700 RWHP with 637TRQ.
"Even though at the time the ZL1 was right around the corner, I wanted something to stand out from the rest," remarked John.
The LS3 is topped with a Magnuson TVS 2300 blower with a ported RevXtreme 92mm throttle body. Other engine mods include a ZL1 fuel pump, coated and wrapped Kooks long-tube headers, SLP exhaust, and a cog drive from Supercharger Connection. He also upped the boost to 12 psi and added a methanol kit to keep detonation in check.
Cunningham Motorsports added a custom-ground COMP bumpstick to further up the performance. To help slow the beast down, he went with a complete brake upgrade system from Granatelli Motorsports.
The list goes on and on: Pfadt camber kit, Airlift Performance air suspension system, poly subframe and differential mounts, spherical control arm bearings, and that's only the tip of the aftermarket iceberg. John also decided to make his ZLX Camaro stand out from the crowd visually with a Z-Force hood, ZL1 front bumper, and a host of body tweaks like an MPD1 Z-Force Ram Air Hood, MPD1 Rear Spoiler, MPD1 Smooth Rear Exhaust Panel, 3dCarbon Ground Effects Kit, 3dCarbon Front Fender Vents, and an APR Carbon Fiber Front Splitter with Stainless Steel Support Rods.
Wheels are 20-inch Staggered Niche M168 Verona Gloss Black Rims wrapped in Nitto Invo rubber, 275/40/20 Front & 315/35/20 Rear.
And with over 700hp to the wheels, you’re going to need all the traction you can get. The car was built to handle power and be as bullet proof as possible, addressing any and all questionable issues that could arise from the increase in HP. It was built with an open checkbook (thankfully John’s). This is a true one of a kind show-and-go car!"
Asking $35k Or "BEST REASONABLE OFFER"
Current Odometer Reading: 15,282 (Number will go up as I still compete in car shows)
VIN: 2G1FT1EW2B9200593
NOTE TO BUYER: Car was financed with State Department Federal Credit Union who has the title in their possession until paid in full.
Sound clips:
https://youtu.be/k1OMl8hq6Ow
https://youtu.be/8lxqPDEywzE
https://youtu.be/pBftbYavO9g
https://youtu.be/FTgiW6aHoYE
https://youtu.be/YGfsMS90Wy4
https://youtu.be/G22sAsxhMG8
https://youtu.be/nh5MXp2oxU8
https://mbasic.facebook.com/story.ph...103110502&_rdr
Performance
*SLP TVS2300 supercharger
*Innovators West 8 rib pulley conversion
*3.6 blower 8 rib pulley conversion
*Rear OD cog drive
*Mild CMS spec custom comp cam
*Cam retainer
*CHE rocker upgrade
*Hardened rods & pistons
*BTR extreme spring kit
*Kooks black powder coated ceramic coated long tube headers with SLP X pipe
*SLP loudmouth II exhaust
*McLeod RXT twin disc clutch
*GForce 1000 HP axles
*Eaton Detroit TruTrac Differential with BMR poly-urethane Bushings
*ARP head bolts
*Injector dynamics 850cc injectors
*160* Thermostat
*Jannetty racing super tensioner
*ZL1 fuel pump with ADM fuel pressure control module
*1LE PCV oil separator
*NKG 6 spark plugs
*Granatelli High performance 80k coil packs & coil near plug connection kit
*RX monster catch can & ported, painted 92mm throttle body
*Alky control methanol kit
*Hurst leather wrapped short throw shifter
*Custom hydro dipped CAI open lid cold air system for true ram air induction Z-force ram air hood
*Auto meter dual gauge A-pillar pod with pro-sports air/fuel and boost led gauges
*Granatelli stainless steel brake lines
Suspension
*Airlift Performance Suspension System that can be controlled by your mobile phone
*Pedders FE4 ZL1 sway bar conversion: adjustable 27mm front & 32mm FE4 rear bars
*Pedders differential & rear bushings
*Pedders front upper & lower arm bushings
*Pedders front radius arm bushings
*Pfadt camber plates
*Pfadt front trailing arm street spherical bearings
*Pfadt rear trailing arm with polyurethane bushing and anodized aluminum sleeves
*Pfadt rear tie rods & bushing kit
*Pfadt trailer arm bearings
*1G granatelli suspension brace
*BMR poly-urethane sub frame mount and bushings
*Granatelli Extreme Performance slotted & dimpled rotors
*Hawks HPS Ferro-carbon brake pads
Exterior & Engine Bay Modifications
*MPD1 Z-force Ram Air hood
*MPD1 Rear spoiler
*MPD1 smooth rear exhaust panel
*3dcarbon ground effects
*3dcarbon front fender vents
*ZL1 front bumper conversion with oracle red and white lighting hidden grill with remote
*Black heritage grill
*Oracle P13w plasma DRLS & fog lights
*Oracle color shift 2.0 halo lighting on headlight and DRLS with RF remote
*Retro Headlight Covers
*Custom painted and supercharged lettered strut tower brace
*Oracle lighting 9 LED board
*Red and blue ambient foot well lighting
*Oracle HI-intensity LED tinted reverse light
*Showstopper Ghosted LED Side Mirrors
*Matte black tail light bezels
**Custom hydro coated radiator shroud, fuse box cover and SLP engine covers
*Black billet locking fuel door
*All retaining hardware has been replaced with stainless steel hex bolts & washers
*Showstopper black billet custom battery terminal
*Showstopper black billet reverse light surround
*Showstopper ABS matte black cover
*Showstopper matte black radiator shroud cover
*Showstopper matte black wiring loom cover
*APR carbon fiber front splitter
*Custom Rally Stripes installed by Elite Custom Installs, LLC and coated with Kenzo by Tango-Mike's Professional Automotive Detailing
*Entire car has been coated and treated with Kenzo by IGL (http://www.iglcoatings.com/kenzo/) By Intoodetails, LLC Professional Detailing
Interior Modification
*Pioneer 7" touchscreen AVIC-Z1406H navigation receiver with Sosche touchscreen HVAC, door locks, hazard and heated seats function
*Full floor & trunk dyno mat sound reading protection
*6 speaker Moral Supremo speakers
*Custom fiberglass trunk mounted leather wrapped & stitched 10" Dynamic sub-woofer
*Custom fiberglass trunk mounted leather wrapped & stitched Amp board with ARC audio 5 channel 500 watt amp
*Custom painted glossy black interior door panels, dash strips, tach/speedo bezels, steering wheel bezel, center console center section, long center console strips
*Valentine 1 radar/laser system with display in rear view mirror
*Showstopper black billet cup holder insert
*Showstopper black billet door lock bezels and pins
*Black powder coated diamond plate floor mats with ZLX inserts
*Custom black plush trunk carpet
*Advanced Composite Specialties Custom painted house of color paint black with blue metallic flake rear deckled cover with 2 LED spot lights
*Custom Embroidered Headrests *Custom LED Rear Window Wind Restrictor Logo
Wheels and tires
*Gloss Black 20" Niche’ Milan Wheels 9" Front with 275/40/20 Nitto Invo & 10" Rear with Nitto Invo 315/35/20 Wheels have been coated and treated with Ceramic Pro (https://ceramicpro.com/)
mov is offline   Reply With Quote
Old 08-03-2018, 07:02 PM   #2
Bottom Dweller
Drives: 2010 2SS RS
Beautiful Car!! I might have missed it but how many miles on her?
Bottom Dweller is offline   Reply With Quote
Old 08-03-2018, 07:42 PM   #3
mov
mov's Avatar
I didn't realize that I left the mileage off. Currently as it sits in the garage it has 15,282 on the odometer. Thanks for catching that... I just updated my post.
Old 08-24-2018, 11:27 PM   #4
Raider-ss
Drives: looking for replacement
Bump for and awesome car and excellent build thread by Kronix. Are the stripes paint or vinyl?
Raider-ss is offline   Reply With Quote
Old 08-24-2018, 11:33 PM   #5
Raider-ss
Of course the one line I skip addresses the stripes.
Old 08-27-2018, 06:58 AM   #6
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
Damn shame I can no longer drive a stick...sweet ride..
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 08-27-2018, 07:47 PM   #7
You Won't
Nothin wrong with dreamin
You Won't's Avatar
Drives: Camaro SS
Awesome ride. Just a shot in the dark but is it still available?
You Won't is offline   Reply With Quote
Old 09-12-2018, 07:05 PM   #8
mov
mov's Avatar
Car is sold! Please close this thread...
