Drives: 2012 ZL1 Join Date: May 2017
Ceramic coating removal
OK guys. A few months ago I did a ceramic coating on my entire car including the wheels. That stuff is GREAT. Makes cleaning a breeze. Now I decided to put some serious tire on the car and am concerned about the tape weights not sticking since I did the barrels of the wheels as well. So my question is, how do I remove the coating for the new weights?
Finishing polish will take it off. I'm sure you polished the car before applying your coating, so just use whatever finishing polish you have.
If you don't have a small polishing machine at your disposal, a foam wax application disc will work by hand.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
Sullie63
Drives: '15 1LT Summit White Join Date: Mar 2015
Did you coat the back side of the wheel, the barrel i guess it could be called. ?
If not maybe the weights could go there.
Casper, Ghost of Camaro's past Black '86 Silver '85, VR '13
Auto/19's/Boston Acoustic speakers/Spare Tire Born 10/28/14 Adopted 04/09/18 with 17,491.xx miles Oracle clear side markers / LLmar tint sides and rear. Strut bar / Husky Floor liners Member of SICC. Southern Illinois Camaro Club |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
^^ This. Ceramic coatings can be removed by abrasion.
Don M
Supercharged LGX + 6 speed manual = FUN!! |
Thanks guys. One guy told me I would have to wet sand it. I was hoping NOT to have to sand it.
#6 |
![]() Drives: Very Shiny Join Date: Nov 2015
Wet sanding is not needed! A light fine polish and a "soft" foam pad on a Dual Action (DA) polisher will remove a ceramic coating.
