![]() Drives: C5 Join Date: Jul 2018
Looking at buying this zl1 question about oil psi
Hello I'm looking at buying his car in Austin, TX. It's a 2015 zl1 with 9k miles. I looking at some pics of the gauges and it shows the car warmed up and the guage is showing around 23psi. I've been doing lots of reading and I read that someone with around 20 psi of oil pressure resulted in replacing lifters. What do you guys think?
Here is another angle, I live 4 hours away from the cars location so I wanted to get you guys opinion before I head up there. The vehicle looks to be stock from pics.
![]() Drives: 2014 ZL1 Join Date: Feb 2017
Mine runs about 30 but I have several mods which includes the better Melling oil pump. Does it still have any warranty left? I drove 8 hours to find mine. Good luck.
I'm sure it still has 2 years left on powertrain. I was definitely about to go buy this car until I saw this lol.
![]() ![]() Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
While I do not have a ZL1 my SS will run in that range once it’s good and warmed up, this is at idle of course. I’m sure you will find it in the normal range for the factory pump.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Miss Con Ception Join Date: Aug 2016
As long as it is between the hash marks either side of center it is within specification.
2011 1SS/RS LS3 CGM
#7 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
I just let my car idle for 20min to check it. It's at 29psi idle. With an oil and filter change that car might be up there close. Can't say its ok where it is or not.
I thought the lifter problems were the L99 automatic SS's, not the LSA ZL1's. |
#8 |
So I called a Chevy dealer about the vehicle and was told that they have been recently switching to 0w20 oil on the newer zl1's. He said the in the earlier models 2013 and lower they where using 5w30 wich would should slightly higher oil pressure. Can anyone confirm this?
#9 | |
![]() ![]() ![]() ![]() ![]() Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
Two different motors.. |
#10 |
I know the lt4 vs lsa, but he was referring to 2014-2015 zl1. I contacted the dealer that did the oil change on this vehicle and he said it was done 12/17, they used Mobil 1 5w30
#11 |
![]() Drives: 2013 VR ZL1, M6 Join Date: Nov 2017
2012-2015 ZL1's should have all used 5w30 dexos approved oil.
#12 |
![]() Drives: 2018 SS Join Date: Jul 2017
I never rely on the factory gauge. They seam to be 2to 4 lbs off
#13 |
My gauge has always sat there after warm and at idle, comes right up with rpms. This is both at stock and after mods. The gauge is only good for you have pressure or you don’t.
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
It looks normal. Mine looks similar after about 5 minutes at idle.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic '25 Silverado 1500 High Country 6.2L |
