Old 08-07-2018, 12:58 PM   #1
Kilroy396
Drives: 2011 2LT RS, Imp Blue, Auto
Time for new plugs and ???
My '11 LT2 RS has just hit 100K and it's time to get the plugs changed. Any recommendations on other things that should be replaced? All stock except for a K&N Filter.
Kilroy396 is offline   Reply With Quote
Old 08-07-2018, 01:27 PM   #2
00 Z/28
00 Z/28's Avatar
Drives: 2011 Camaro SS/RS
If they haven't been changed already, serp and ac belts.
2011 SIM 2SS/RS L99/A6, Rotofab CAI, TSP LTs & hi-flows, SW Retro catback, BMR & Hotchkis goodies, MRR 017s & Nitto 555G2s
00 Z/28 is offline   Reply With Quote
Old 08-07-2018, 01:47 PM   #3
LETHAL2SS
LETHAL2SS's Avatar
Drives: 2011 Camaro 2SS
100k mile recommendations for most manufacturers:
Spark plugs
Trans fluid flush (or fluid change if your M6)
Coolant flush
Rear differential flush
Brake fluid system flush
Power Steering fluid flush
Check all belts and hoses for cracking or tears, replace if needed.
This is a general rule of thumb for almost every vehicle at 100k.
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp
LETHAL2SS is offline   Reply With Quote
Old 08-07-2018, 02:31 PM   #4
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Might also consider new plug wires while you're at it; at 100K I always replace them as well mainly just for piece of mind.
Old 08-08-2018, 08:02 AM   #5
Kilroy396
Thanks, just what I was thinking, just doing a little sound boarding.
Old 08-08-2018, 09:16 AM   #6
Spurshot
Drives: 2014 2SS blue
Hoses and belts get replaced on my vehicles around that mileage. I also flush the cooling system before replacing hoses.
Spurshot is offline   Reply With Quote
Old 08-08-2018, 09:57 AM   #7
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
I put a set of E3 Diamond Fire Spark plugs in with a set of MSD wires, replace the belts and hoses, if it an auto trans, the filter and flush the fluid with new fluid. You may want to even consider replacing the coils with a nice set of MSD coils.
ZEN357 is offline   Reply With Quote
Old 08-08-2018, 12:49 PM   #8
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
The V6 still does not have plug wires. It's coil on plug. Also only has 1 belt. That said, Lethal2SS pretty much hit the nail on the head.
Might be worth doing an upper induction cleaning if you don't have a catch can though is the only thing I could add.
DSX_Camaro is offline   Reply With Quote
Old 08-08-2018, 02:00 PM   #9
farm rat
farm rat's Avatar
Drives: 2011 Vistory Red 1LS
To clarify what I have posted before. If running an auto and the tranny has never been flushed you dont want to start now. Drop the pan, change the filter and replace the fluid. Flushing an auto can just move crap into places you dont want it.
The Original Farm Rat
2011 1LS M6 Victory Red
Sold
1967 Coupe Green and White
1969 SS 396 Hugger Orange
1969 Z/28 All original White with deluxe interior
1970 RS Blue
1978 Coupe Fugly Green
1978 WS-6 Trans-Am Factory 4 speed
1985 IROC-Z Red
farm rat is offline   Reply With Quote
