![]() Drives: 2012 Black 2SS/RS M6 Join Date: Mar 2012
Oil Burning?
I just checked my dipstick 15 minutes after I drove my ss and I see oil only at the bottom of the dipstick. No where near the x's. I drive pretty aggressive on the street but should this be happening? There are no leaks in my driveway. Is this normal? Just got an oil change not too long ago
Pfadt Race Engineering 1.25" Lowering Springs| Pfadt Spec Performance Street Alignment|ZL1 Front Bumper Conversion|ZL1 20x9 Rims|Pirelli P Zero All Season Plus 275/40R20Y Square Setup||Footwell Lighting|G2 Gold Painted Brake Calipers
Stainless Power Long Tube Headers|Cold Air Inductions Cold Air Intake|VMAX CNC Spiral Ported Throttle Body|Stainless Works Retro Chambered Catback| Vitesse Throttle Controller --Jannetty Racing Enterprises Dyno Tuned|408 RWHP |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Miss Con Ception Join Date: Aug 2016
Check it again in the morning before you start it.
2011 1SS/RS LS3 CGM
I did that the time before this and same results
Did you check it after the change?
Some have reported they only put in 6 quarts instead of 8. Top it up and keep an eye on it.
2011 1SS/RS LS3 CGM
any certain amount i should be putting in it at first?
#6 |
Dump in a quart and then see where it is on the stick. The 'add' mark (bottom of the Xs) is one quart. Better to be a little low than overfilled. If you are running synthetic it will run into the pan pretty quickly. If dino oil you should wait some time for it to drain down.
2011 1SS/RS LS3 CGM
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Exactly.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
#8 |
so I put in 1 quart and its coming right below the bottom of the x's..Should I put in any more?
#9 |
You should add another quart. The level should always be within the X's.
Sounds like they only filled it with 6 quarts like the V6s take.
2011 1SS/RS LS3 CGM
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
I am curious who the hell changed your oil without checking the recommended oil capacity.
#11 |
I definitely got charged more because they said I have an 8 quart engine capacity...I'd be surprised if they didn't fill it to 8..they showed me the dipstick after and it was in the x..maybe just from driving hard it went down?
