cai cold air fitment issue
just curious if anyone elses cai is crooked and has everything in a bind like mine. the others on cars around here I've seen are not like this.
'11 2SS/RS M6
old school chevy rodder
no but I have a 13 with electric PS....
I did opt for the relocate of the washer bottle and a scoop also. You may want to make sure your tube is all the way into the band for the TB so it lessens the angle, also I noticed its important to keep the MAF tight when cleaning it..got a code once and its seal is real important. I do tuck the lid in on the right into the area under the pinch weld and engine bay weather stripping. And the area it fits is tight so anything in the way you may want to look at and get the box geometry right.
yea i’m going to remove the washer bottle, never use it anyhow. i have the bumper scoop but kinda lazy with this weather and humidity. even with the tube shoved all the way against the TB it’s still like that, like it’s a little to long, either the tube or air box. where did you find those coil covers?
'11 2SS/RS M6
![]() Drives: 2011 Chevy Camaro SS Join Date: Jun 2017
That's exactly how mine installed and it seemed a little odd. Still works fine and was able to finish the installation. Just didn't mount up quite as flush and straight as I thought it would. I emailed CAI even about one of the clamps not tightening correctly as it was stripped somehow already and I never heard back from them. Makes me want to email them and ask them about this as well but not sure I would receive a response. Seems like a new intake tube with less of 90 in it would take care of the issue
I emailed them about the same time i posted this and got a reply yesterday and sent them some pictures, see what happens.
'11 2SS/RS M6
#6 |
Yeah I'm curious to see what they say. I will have to follow this thread to see because if it results in being sent a new elbow I'm going to be picky and do the same. Bugs me how it doesn't exactly mount up flush.
#7 |
![]() Drives: 2011 Black 2SS Non RS L99 Auto Join Date: Jul 2016
Here's mine no issues
#8 |
![]() ![]() Drives: '14 BRM 1LE 2SS/RS Join Date: Nov 2017
Mine is about like KansasSS's, slightly crooked but maybe not as bad as yours
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Mine fits perfectly , but I did the washer bottle and scoop at the same time .
OLD GUY FLYING FAST AND LOW
#10 |
so as of right now they're saying its improperly installed. see what happens in the next few emails. I am to dang anal about stuff like this to leave it like that.
'11 2SS/RS M6
#11 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
Here’s mine:
#12 | |
![]() Drives: 2012 Camaro SS Transformer Join Date: Sep 2013
The hole in the sheet metal box drives location one end of tube, throttle body connection the other. Tube is one piece, goes in one way. Not sure how they thing install is wrong. Maybe perspective of pics but looks like hole in sheet metal is rear more than mine?? And possibly portion of tube at throttle body looks longer plus bend radius looks bigger. All causing tube to be at angle rather than more straight across car??
Mods: trunk subwoofer and amp, LED lighting (fogs, interior, trunk), skip shift eliminator, CAI cold air kit, Vmax ported throttle body, Stainless Works retro chambered cat back, JBA Cat4ward SS ceramic coated headers Potential Next Mods: Tune, F&R sway bars, rear cradle bushing inserts and trailing arms |
#13 |
that’s basically what i told them. they wanted me to loosen all the clamps and move it in closer to the throttle body but obviously i can’t let it touch the TB. i am not sure if it’s to long or the angle is wrong. half tempted to buy another if they don’t want to fix it.
'11 2SS/RS M6
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
My air tube is tight up to the TB and have never had a problem with it.
