Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 08-12-2018, 05:42 PM   #1
1QIKZL1
Drives: N/A
Cool 2017 ZL1 - Marble Sound in Front Wheels
All;
Looking for some input - today I heard what is "Mable" sound when turning left and turning right at low speeds. The car has 7100 mi. Rotors? Brakes? Wheel bearing? No issues with stopping and no vibrations. All lugs tight.
2017 Camaro ZL1-Silver Ice/A10/PDR/NAV/RF-Sold
2018 Traverse AWD-Silver Ice/V6/Special Order-Own
2016 Chevy SS Sedan-PBM/A6/Roof/Spare-#256-Sold
2014 Chevy SS Sedan-PBM/A6/RF/Spare-#326-Traded
2006 Suburban LTZ AWD-Traded
2005 Silverado LTZ 2500 4x4 Diesel-Traded
2003 Avalanche LTZ 4x4-Traded
1996 Corvette C5 Grand Sport LT4-#417-Sold
1996 Corvette C5 Collector Edition LT4-Sold
1989 Corvette C4 Red on Red - Sold
1QIKZL1 is offline   Reply With Quote
Old 08-12-2018, 05:47 PM   #2
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Wish I had an answer, might get a better response if you post in Camaro6 ZL1 forum. Good luck.
HOJO is offline   Reply With Quote
Old 08-12-2018, 06:10 PM   #3
hammdo
'It's an experiment'
hammdo's Avatar
Do you have the brake air deflectors? Wheels rebalanced recently? If so see if the weights hit the deflector...
-Don
747 RWHP 794 RWTQ
Old 08-12-2018, 07:14 PM   #4
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
Anything in your glove box, console, etc? lol
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 08-12-2018, 07:19 PM   #5
1QIKZL1
Drives: N/A
Cool
Thanks for at least getting back to me!
Old 08-12-2018, 07:20 PM   #6
1QIKZL1
Drives: N/A
Cool
Just the normal manual and wheel lock..
Old 08-12-2018, 07:21 PM   #7
1QIKZL1
Drives: N/A
Cool
-Don
No but I was going to take in and have rotated and rebalanced. Maybe that will solve the issue..
Old 09-10-2018, 12:14 PM   #8
Rock510
Drives: 2012 ZL1
I have the same problem going on with my truck. Sounds like front driver side wheel.
It's probably a failed wheel bearing or a unbalanced tire causing vibrations. Good luck. Let us know if you figure it out.
Rock510 is offline   Reply With Quote
Old 06-11-2019, 06:38 PM   #9
carjockey71@gmail.com
Drives: 2012 Chevrolet Camaro SS Convt
I had that ‘marble’ noise as well -
Each time my right front tire went 1 ‘revolution’ or around 1X it would click, bump, thump, bang, whatever you would like call it to describe the noise, once you’re going 20-30 mph and it sounds like a bunch of marbles rolling around and the faster the tire turns the more ‘clicks’ there are - I went absolutely bananas trying to figure it out.
Clutch in / clutch out no difference, turning the wheel no difference, backwards no difference, engine on engine off no difference no matter what happens there was no difference.
My issue would up being my rotor was ‘out of round’ it’s a very silly mistake to make, so when I installed my left front rotor I had ‘rotor run out’ because I didn’t bother to ‘gauge’ for lateral runout, 5 minutes and a gauge to determine the thickness of the new rotor and proper placement and it would have been a very simple adjustment and that would have been the end of it.
You can have ‘run out’ for a a bunch of different reasons, there is really no reason that this should of happened, I was lazy and my short cut cost me a small fortune. I had to repurchase all new brake parts which included a new rotors, pads, caliper kit, bushings, bolts and all the other equipment to make sure it sat ‘true’ against the wheel assembly
I will NEVER make that mistake again, hope it helps
Paul
carjockey71@gmail.com is offline   Reply With Quote
