Old 08-13-2018, 09:41 AM   #1
BacktoGM
BacktoGM's Avatar
Drives: 2019 Black SS
Front Rotors/Pad
I replaced the front factory rotors with StopTech slotted / drilled and they finally warped. Surprised about that since I don't track or race the car. In any event, any suggestions on replacement rotors / pads. Thought drilled rotors would have not warped
Thanks,
Stephen
BacktoGM is offline   Reply With Quote
Old 08-13-2018, 07:43 PM   #2
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
Drilled rotors aren't worth the trouble. Slotted make since. Drilled rotors do not provide any performance improvement. They can actually reduce performance. They are also prone to cracking. High end race cars use drilled rotors but that is more for weight reduction than anything else.
I use factory rotors, I track my car 12-18 track days per year. I haven't had any issues with warping.
A man's garage is his castle
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2014 Camaro SS Dedicated Track Car
2015 Camaro 1SS 1LE
2008 HHR SS
1996 Silverado Crew Cab Long Bed Dual Rear Wheel
SS Performance is offline   Reply With Quote
Old 08-15-2018, 03:04 PM   #3
BacktoGM
BacktoGM's Avatar
Thanks Man.
I saved the factory ones. I am putting them back on. More later.
Thx.
Old 08-19-2018, 10:25 PM   #4
49North1LE
Drives: 2015 2SS/RS 1LE G7C,
My two cents after looking around, I choose Baer grooved Eradi-Speed two piece rotors all around. Stayed with stock Brembo callipers & pads. Saved a few pounds of rotating mass and they look great.
49North1LE is offline   Reply With Quote
brakes, pads
