![]() Drives: Camaro V Join Date: Aug 2018
Strange engine operation
Good afternoon.
The 2013 car, 3.6 LFX. Can someone faced, a problem essence in the following: Sometimes writes an error p0191 incorrect value in a fuel ramp, stabilitrak off, power of the engine is reduced. When you turn off the ignition, the motor can work for another 1-2 seconds. I think in the direction of the high-pressure pump, can someone faced? Thank you! I apologize for my English, greetings from Moscow ) |
![]() Drives: 2015 Camaro Convertible V6 Join Date: Mar 2018
sounds like this thread. https://www.camaro5.com/forums/showthread.php?t=521530
Thanks, the gaskets are on order. I will try. In General, the injectors jump after the error in the opening values -10 to -40, when there is no error + - 2.0.
![]() Drives: 2012 Camaro RS 2LT 6spd man Join Date: Aug 2013
Wow! welcome hazard!
