Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Engine Internals
Old 08-14-2018, 11:35 AM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
Thumbs up NOW AVAILABLE!!!! Fuel Injector Clinic Injectors
NOW AVAILABLE!!!!
FREE SHIPPING at PHASTEK PERFORMANCE!!!!
Fuel Injector Clinic complete sets of 8 injectors. Saturated / High Impedance Injectors. Drop in plug fitment! Some of the bigger injectors will require you to change the injector plug on the wiring harness in your car. This can be done by soldering in the pigtails (included with purchase) to replace the plugs currently on your harness, or you can choose to purchase the optional plug-n-play adaptors which will convert from the type of plugs on these injectors to the plugs on your harness without any need for cutting or soldering.
This plug conversion is made necessary because FIC always chooses to provide brand new, unused injectors for its performance applications. We do not believe that increasing the chance of a failure due to using re-manufactured or core program based injectors is ever warranted.
Fits: 2010-2015 SS and ZL1 only.
Features:
  • These injectors utilize the latest technology and provide great linearity and short pulse width repeatability.
  • Plug and Play GM ECU Data Available at http://fuelinjectorclinic.com/GMData
  • Injector sets are precisely flow matched to within 1%. Each injector within each set is individually numbered and results for each injector are listed on a detailed flow sheet included with the set.
  • Flow tested and rated at 43.5psi (3Bar) at 90 degrees F fuel temperature using CF-16B calibration fluid.
  • Superior short pulse width control and tight manufacturing tolerances make these injectors easy to tune and provide great drivability.
  • Injectors are set up to and include all o-rings needed to fit the factory application.
Plug In to Factory Harness:
60lbs/hr - #IS303-0540H
72lbs/hr - #IS303-0660H
94lbs/hr - #IS303-0850H
110lbs/hr - #IS303-1000H
Require Solder in pigtails/Plug in Play Adaptors
97lbs/hr - IS303 -0880H
130lbs/hr - IS303-1200H
180lbs/hr - IS303-1650H
240lbs/hr - IS303-2150H
Sales@Phastek is offline   Reply With Quote
e85, fuel, gas, injector, phastek
