More than meets the eye
Drives: 2SS RS M6 06 Jetta TDI 17 Civic EXL Join Date: Jul 2009
has any one been speed shifting and accidentally hit 3dr when aiming for 5th?
I have the 2SS 6M rolling start from 1st hammered it, shifting before 5500 (break-in says not to go over 6000) anyway made it to 4th keeping it under 5500 at each shift and when shifting 4th to 5th hit third again! ![]() Wholly molly scared the you know what out of me I bet it pegged to 7500 before I could disengage. Seems to be ok but wonder if I hurt it?
Why are you speed shifting 4th to 5th? You should be through the quarter mile by then. There is a spring that keeps the gear shift lever in the middle gears. From 1st to second you are holding the lever to the left against the spring. Second to third the spring centers the lever and you get 3rd. For 4th you pull straight back and springs keep the lever centered. To get 5th requires a pause in neutral while you move the shifter to the right to overcome the spring, then up to 5th. For 6th, you keep the lever right to overcome the spring as you pull down. I am assuming a standard shift pattern on the Camaro. But you get the idea. The lever just naturally wants to go to third.
On most cars, the rev-limiter will not save the engine if you get the wrong gear at high RPMs. The limiter likes to see the revs coming so it can prepare to restrict timing or fuel flow or whatever it does. It doesn't protect you if it sees 7500 RPM all at once. Maybe you should stop doing it. I never speed shift, so hopefully others who do can offer better advice if you wish to continue. Cheers. |
#3 | |
![]() ![]() Drives: 2010 Camaro 2SS Join Date: Aug 2009
Guest
Anybody that tells you they never missed a gear in a manual is lying. I've done it a couple of times. If it didn't break anything right away I wouldn't worrry about it.
NEcamaro5
just tell me you whent with it and floordit.I to have done that .
#6 |
![]() ![]() Drives: Corvette ZO6 CSR edition #47 Join Date: Apr 2009
I had the same problem a few times as well. Its the shifter I tell you. I replaced it after the third missed gear. MTI racing makes a great one. Never missed a gear since.
#7 | |
I thought as much that 4th should be the last shift Where 5th and 6th is just for cruising.
#8 | |
I did want a Hurst but heard this MTI shifter is smooth like butter and a lot quieter than the Hurst plus it does not cost as much.
#9 | |
did I jut peg that tachometer.scared the tee tee out of me
#10 | |
#11 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
#12 | |
I just wont miss it again or just stop at 4th. But up to that point shifting even at 5500 what a rush the car will flat out fly, and the torque is whoa. I can see how horse power can become addicting.
#13 |
Drives: IOM 2SS RS M6 sunroof Join Date: Jul 2009
Put in a MGW shifter and you wont have that problem again !!!!!!
#14 |
The problem with speed shifting is that you are using a death grip on the shifter and ramming it where you think it should go bypassing the spring protection and any feel you might have. May work for straight ahead drag racing, but on a road course where there are various side loadings that could affect your hand movements, it is a no-no. Unless you are drag racing, use a light grip and just guide the gear lever into the desired position. Your transmission will certainly last longer. Not necessary to beat on our cars to enjoy them.
Advice from an old fogey, eh. Sorry about that. Feel free to ignore the above, which I am sure you will. Cheers. |
| My thoughts on the 5th Gen...from a 9 year 4th Gen owner | TAG UR IT | 5th Gen Camaro SS LS LT General Discussions | 75 | 07-19-2011 10:30 PM |
| 4th Gen 1/4 mile times versus 5th Gen 1/4 mile times | Rock36 | Dragstrip and Launch Techniques Discussion | 52 | 07-29-2009 11:01 PM |
| Interested in getting a 3rd gen... | MAC | 3rd Generation Camaros | 22 | 03-18-2009 12:37 PM |
| 4th gen, 5th gen poll | TonytheTiger | 5th Gen Camaro SS LS LT General Discussions | 29 | 12-12-2008 12:13 AM |
| Condensation in late 4th gen headlights? | MAC | 4th Generation Camaros | 27 | 06-30-2008 02:53 PM |
