Old 08-24-2018, 09:37 AM   #1
pony
pony's Avatar
Drives: 2011 2SS Convert; Color RJT
Transmission Cooler routing options and affects on engine temp
I'm planning on installing a stall converter on my L99 with some modest mods. I've read till I can't see straight but have some questions hopefully someone else has experienced and can chime in.
I know I can route through the radiator and then through the new external cooler. I also have seen where others have bypassed the radiator completely.
Question 1 being, with a stall increasing trans temps, will the engine temp increase due to the higher heat fluid being introduced into the radiator? (My engine temp already runs high 200-teens and one poster mentioned this issue on road racing)
Will a good stand alone stack plate 30-40k Btu front mount WITHOUT separate fan do a good job AND hopefully reduce the strain on engine temp.
I'm trying to avoid adding an oil cooler as well. Any thoughts or actual experience will be appreciated.
pony is offline   Reply With Quote
Old 08-24-2018, 09:43 AM   #2
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
Short answer is No it will not change engine temp.
On my GTO I'm running a 5k stall I have my fluid going to Rad then cooler with no issues (no fan, cheap jegs cooler).
In my other cars I have always just ran through the cooler and not the rad. Either way you'll be fine.
GJDM
LsxDoctor is offline   Reply With Quote
Old 08-24-2018, 06:30 PM   #3
Bo White
Bo White's Avatar
If your going to run the factory cooler and an aux cooler run the fluid through the factory cooler first then the aux
Old 08-25-2018, 09:38 AM   #4
GRNFLSH
GRNFLSH's Avatar
Drives: 2015 Camaro 2SS Green Flash Edition
3800 stall wth an ADM transcooler run straight to the cooler. They include some capped tubes for the radiator cooler to keep it from junk up in there.
The trans still warms up quickly, helped by the stall, but never gets past 170F on the street, 190F after back to back passes at the track. Unless yours is a DD and wanting help warming the trans on very cold days I dont see any benefit of running through the radiator.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo
GPI VVT SS1 cam and CNC ported heads milled .30
BTR .660 springs, Straub solid bushing trunions
GPI rod-mod intake with I-M heat sheild
Circle D 258mm Pro single disc 3700 rpm stall converter
169F thermostat & manual fan switch
Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft
GRNFLSH is offline   Reply With Quote
Old 08-25-2018, 11:48 AM   #5
Bo White
Bo White's Avatar
Benefit is a more stable trans temp. Mine never moved around when I had mine routed like that. Now that mine i just running the aux cooler mine floats around like that. Just under 180* cruising and just over 180* running it.
Old 09-02-2018, 06:44 PM   #6
hammdo
'It's an experiment'
hammdo's Avatar
I did this:
https://www.camaro5.com/forums/showp...postcount=1689
https://www.camaro5.com/forums/showp...postcount=1702
https://www.camaro5.com/forums/showp...postcount=1703
-Don
747 RWHP 794 RWTQ
