Old 08-24-2018, 12:37 PM   #1
cubamvp
cubamvp's Avatar
Drives: 2013 Camaro
Break pads and rotors
I have a 13 Camaro v6 and I want to replace the front breaks n rotors, any suggestions ? Thanks
Sent from my SM-G930V using Tapatalk
cubamvp is offline   Reply With Quote
Old 08-24-2018, 02:44 PM   #2
swampcritter
Drives: 2014 Camaro LS / 13 zl1
I used the stop-tech rotors and pads and never had any issues with them.Of course I don't race or track it.
swampcritter is offline   Reply With Quote
Old 08-24-2018, 03:02 PM   #3
bingster223
bingster223's Avatar
Drives: 2015 1LT/RS hot red/black
Check out Power Stop breaks. They have a Z37-1404 package and a Z23 package i don't know if the Z26 package fits the v6 If your budget is on the low end. I think the z37 is only front breaks used on cop cars the z23 is good for daily driving.
If price doesn't matter then look at Wilwood, or StopTech. Im sure there's plenty other options available too.
Sent from my SM-G955U using Tapatalk
bingster223 is offline   Reply With Quote
Old 08-25-2018, 11:07 AM   #4
rozarioorlan
Drives: Camaro
You can always do a Brembo conversion.
rozarioorlan is offline   Reply With Quote
Old 08-27-2018, 10:55 AM   #5
Marklar
Drives: 2012 Camaro LS V6
What makes using Brembo a "conversion"? I though Brembo was just a brand of brakes/rotors.
Marklar is offline   Reply With Quote
Old 08-27-2018, 07:56 PM   #6
ROKDWLR
ROKDWLR's Avatar
Drives: 2015 Camero LT Convertible
I went with the Power Stop Z23 ceramic pads & vented slotted rotors front & rear after installing them on a couple other cars. The best price I found was on EBay. Very happy with their performance.
ROKDWLR is offline   Reply With Quote
Old 08-28-2018, 10:08 AM   #7
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Brembos off the SS or higher model Camaro. There's no V6 Brembo package. You convert to what the V8 models use.
DSX_Camaro is offline   Reply With Quote
Old 08-29-2018, 02:31 AM   #8
rocknroll_jeph
rocknroll_jeph's Avatar
Drives: 11 Camaro V6 RS, 03 BMW Z4
I tried all kinds of pads for mine and was never that satisfied. I bought brand new 4 piston Brembo's for a Cadillac that are direct bolt on (around 150$ from ZZ Performance). They came with power stop brake pads, which I didn't like. I always use EBC red or yellow stuff now. I also bought some SS rear brakes from another member from this site. The stopping is much better, but still leaves a bit to be desired. My other car is a BMW Z4 with amazing brakes, so maybe I shouldn't compare to that car.
rocknroll_jeph is offline   Reply With Quote
Old 08-29-2018, 08:44 AM   #9
Marklar
Well yea! The Z4 weighs ~800lbs less, no wonder it's easier to stop!
Old 08-29-2018, 09:08 AM   #10
Michaelthurston
Michaelthurston's Avatar
Drives: 2013 Vert Ashen Gray
Personally I just replaced my brakes with Duralast max rotors and pads all around, and I felt like i was getting good OE brake performance.
That being said, about 3 weeks ago I stumbled upon a great deal on a set of brembos from a 2010 SS. The V6 stopping power is good, but this is a completely different feeling, and I wouldn't go back.
Michaelthurston is offline   Reply With Quote
Old 08-30-2018, 12:53 PM   #11
cubamvp
cubamvp's Avatar
Drives: 2013 Camaro
Is it hard to convert to cambro on a v6?
Old 08-30-2018, 12:54 PM   #12
cubamvp
cubamvp's Avatar
Drives: 2013 Camaro
I dont race my car either. How much are they ?
Old 08-30-2018, 12:55 PM   #13
cubamvp
cubamvp's Avatar
Drives: 2013 Camaro
Thanks.
Old 08-30-2018, 12:56 PM   #14
cubamvp
cubamvp's Avatar
Drives: 2013 Camaro
How much were those? Thanks
