Old 08-25-2018, 04:58 PM   #1
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
tubular front crash beams
I'm going to start making these to sell on the forums.what's shown is 1 and 5/8 pipe. I have (5) made up of 1 inch chromoly. I can do whatever other size you may want/need but 1 inch would be the smallest I'd want to go. total weight is around 3lbs with the 1 inch.
longer wait times if I need to order another size pipe.
$225 shipped to the lower 48 on the 1 inch. others will be slightly more depending on size desired
ttshovel is offline   Reply With Quote
Old 08-25-2018, 06:26 PM   #2
Nb1081
Drives: 10 2ss/rs
Whats the weight savings over stock
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
Old 08-25-2018, 07:01 PM   #3
ttshovel
ttshovel's Avatar
it's around 13lbs and l loads of clearance
Old 08-25-2018, 08:02 PM   #4
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
How these actually hold up in the event of a crash?
If you somebody hit you, what would insurance say?
Strongly contemplating these for front and rear.
Old 08-25-2018, 08:09 PM   #5
ttshovel
ttshovel's Avatar
I can see these holding up decently if you went with a slightly larger tube. but this small would be just to prevent front end sag when removing front for clearance..
insurance i don't know about
Old 08-26-2018, 09:57 AM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
What about tow hook options and what kind of welding technique MIG or TIG??
Orange Krush II
Old 08-26-2018, 11:05 AM   #7
ttshovel
ttshovel's Avatar
they're tig welded. I'd have to think about the tow hook as an option. maybe a threaded one that is removable?
Old 08-26-2018, 12:28 PM   #8
Baddbird
Baddbird's Avatar
Drives: 2014 2SS
13lbs saved or the total weight is 13lbs?
Baddbird is offline   Reply With Quote
Old 08-26-2018, 03:27 PM   #9
ttshovel
ttshovel's Avatar
13lbs saved.
Old 11-07-2018, 05:54 PM   #10
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Are these just for front bars right?
How much for 2” size tubes?
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 11-07-2018, 06:13 PM   #11
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
https://www.leftcoast32.com/shop-per...formance+Parts
Left Coast 32 already makes these for the Camaros.
SSEssence is offline   Reply With Quote
Old 11-07-2018, 06:42 PM   #12
Jayjellyfish212
Drives: 2014 1LE
Oh cool. Thanks man!
Old 11-08-2018, 10:22 AM   #13
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
13 lb weight savings just for the front?
zz430camaro is offline   Reply With Quote
Old 11-08-2018, 02:41 PM   #14
Jayjellyfish212
Drives: 2014 1LE
Nahh.. from what I’m seeing for the front is about 7-8lbs saving from what’s available on the market so far. Stock front one weights 14.2
The biggest weight reduction is on the back one. I have not gotten to back yet. I got my front end fully off right now for oil cooler upgrade and figured I’d look into doing the front bar now since it’s already apart. I’m considering just making my own following my research so far.
