Old 11-25-2009, 07:02 AM   #1
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
Transmision Output Shaft: Solution for GM
Admin and Mod's, please sticky this thread so most can see it without having to bump it.
GM, why don't you do this...? (Yes, I'm creating its own thread because I feel it is important enough)
1) Have the dealers replace all trans output shafts defective or not (within the vin range of affected vehicles) with ones that you know are created correctly.. You take each shaft and have them tested at your own time to declare them viable to be recycled or used again.
This is the easiest and best solution yet since it would save you guys from an embarrassment and a large legal payout if someone does die in the future due to this issue. Not to mention all the bad publicity you will get. Look at Toyota as the example.
For those of you with Camaro's within that VIN range, post your Camaro SS M6 and VIn number and post that you support GM doing this. If you've already had this issue, also post in this thread and let us know as well. Thanks
So Scott Fbodfather, if you are reading this, please suggest what I just wrote above to GM's higher authorities so they can make it happen and end this ridiculous back and forth of speculation and playing with our lives with a known potentially dangerous issue. GM can do this and problem solved. Make it happen. Let us know that you tried.. Thanks..
Quick Explanation of problem for newbies
If you are a Camaro owner and do not know about this issue, there are numerous threads about it. In a simple four sentence explanation, a bad batch of Transmission Output Shafts has made it into many V8 M6 Camaro's causing them to snap under normal driving conditions in some cases and while using the car under normal strain on the track via launch control. It is an unknown how long it would take for it to fail or break if all you do is drive it normally if you are one affected. This is a potentially dangerous problem if this occurs at a time of oncoming traffic or in an intersection which requires you to get out of the way of vehicles since this you would lose the ability to move once it snaps. So far if you are under the 25,000 VIN range, you may be affected and just don't know it yet.. So post in here if you own a Camaro below 25,000 VIN and if you are concerned.
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline
Old 11-25-2009, 07:09 AM   #2
Supermans
Supermans's Avatar
I will start first.
I want and supprt GM to take this issue and correct the problem using the above mentioned method for those M6's in the VIN ranges that may or may not be affected.
I own a Camaro V8 SS M6
My VIn number is 2G1FS1EWXA9122517
Old 11-25-2009, 08:51 AM   #3
chopss
chopss's Avatar
Drives: 04 sentra, 2ss
I hope this forum takes notice. i really dont want to get strained on a road trip.
i own a 2ss m6 vin 2G1FT1EWXA9120151.
joey
chopss is offline
Old 11-25-2009, 08:56 AM   #4
Ltdodge
Ltdodge's Avatar
Drives: 2008 Z06
I am concerned also
camaro SS M6 #17285
Ltdodge is offline
Old 11-25-2009, 10:10 AM   #5
camarorick
camarorick's Avatar
Drives: .
I've been following this potential problem since it was first noticed.
I am VERY concerned, and would like some reassurance GM.
2SS - M6 - #7195
camarorick is offline
Old 11-25-2009, 10:16 AM   #6
carfansince73
carfansince73's Avatar
Drives: Carefully
I've been following this from when the rumor first started. I am concerned and would like to know what solution GM has to this safety issue.
Vin# 2G1FS1EW3A9118308
2010 1SS RS, LS3, SIM/Black, painted rally stripes, AAC sidemarkers, Sunroof, B.A. sound sys; 20x9.5 & 20x11 SV1-C5's; MGW short shifter; Hotchkis Track Pack; Corsa catback; Kooks 1 7/8"; ADM Street; Magnacharger TVS2300 - 548rwhp/512rwtq
1100- 2/18/09; 3800- 6/15/09 VIN#18308; Delivered 6/29/09!!!!!
2014 CTS-V Sedan, Black/Black, Auto, Recaros, Ultra-view, Red Brembos. Stock
carfansince73 is offline
Old 11-25-2009, 10:25 AM   #7
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
I want to have peace of mine too :(
VIN: 2G1FT1EW9A9110940
JM
JM10 is offline
Old 11-25-2009, 10:30 AM   #8
rharon
rharon's Avatar
Drives: 2010 Yellow 2SS/RS
I am also concerned. You don't want to drive the way the car should be driven because of the fear of snap!
Magnacharger TVS2300, ARH HEADERS, ROTO-FAB CAI, NOWEEDS.NET DIVERTERS
rharon is offline
Old 11-25-2009, 10:38 AM   #9
2001ragtop
2001ragtop's Avatar
Drives: V8 american car
note: this can of worms should not have been opened again and I have a feeling the G.M. executive is going to be very, very unhappy that he has to respond to this again. I cannot wait to read what he posts.
2001ragtop is offline
Old 11-25-2009, 10:48 AM   #10
02b4c
02b4c's Avatar
Drives: 63 splt wnd 55 chev 08 1500
My vin # 7542 I would like to no if any recalls
02b4c is offline
Old 11-25-2009, 10:51 AM   #11
mtm864
Drives: 2010 2SS/RS
i ordered my 1ss on the date in my sig i shouldnt be affected should i?
10 2SS: LM1, K&N drop in. SOLD
14 2SS: stock...ish
mtm864 is offline
Old 11-25-2009, 11:10 AM   #12
Supermans
Supermans's Avatar
It's been 4 hours and 9 people so far are concerned about this. Please sticky this thread so more people get to see it who are within this vin range of vehicles. Thanks for all who posted so far.
Old 11-25-2009, 11:24 AM   #13
AGM76
Drives: 1995 z28 - 2000 SS - 08' vette
and people were giving the GT-R all sorts of grief.
AGM76 is offline
Old 11-25-2009, 12:11 PM   #14
3 SS's
3 SS's's Avatar
Drives: Chevelle SS's
10887 here, and yes i'm concerned, anyone that's not is foolish, IMO
3 SS's is offline
Transmission output shaft hiller72 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 267 12-02-2009 08:39 PM
Tranny output shaft problem vin #'s 3 SS's Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 14 10-21-2009 12:42 AM
6 spd Manual Trans Output Shaft Breakage Magoo Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 10-07-2009 07:44 AM
2010 Camaro 2SS/RS Output Shaft broke KimPossible Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 60 08-31-2009 03:04 PM
Watched a 2010 SS shatter the output shaft last night SK360 5th Gen Camaro SS LS LT General Discussions 60 08-29-2009 11:04 AM
