Old 08-29-2018, 10:54 AM   #1
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
DIY Master Cylinder install?
Does anyone have a detailed description on how to install a master cylinder on an SS. This would be really appreciated
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
Old 08-29-2018, 11:04 AM   #2
xc_SS/RS
Drives: 2010 Camaro SS/RS
give it a few days and i will know how it goes. i'll be installing my tick billet MC this weekend.
hopefully someone else has done this and can give you instructions before then lol
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 08-29-2018, 11:52 AM   #3
booneSS13
booneSS13's Avatar
lol it'll be a little while before I work on it, I'll be looking forward to hearing about it. Tick sells a billet master cylinder?
Romans 5:8
Old 08-29-2018, 12:45 PM   #4
xc_SS/RS
oh nice, i'll do a little write-up on my install then and post it here.
Yep, Tick just came out with their billet MC for a 5th gen Camaro about a month ago I think. It'll come with instructions but I'll take some pics along the way as well. I'm hoping it helps cure my falling pedal under WOT.
2010 2SS/RS
Old 08-29-2018, 01:01 PM   #5
Matt@Tick
Matt@Tick's Avatar
Drives: All GM Performance
Thanks for purchasing. All of the pre order kits have shipped and are on the way, with some already installed.
You will find this is about the most simple kit to install we have ever made. The pedal assembly can be a little tough to remove from the car, but that will be the hardest part of the entire install. I am personally very excited about this new master kit. We have spent lots of time building and testing this kit. We have gone through four different designs until we got what we wanted as the final product.
I have found already that it is a good idea to put some grease on the mounting peg that is on the pedal for the master rod. This will keep it from making any squeaking noise. This is an issue that has come up after we had our adjustment rods coated. I feel like there may be too much coating on them and the fit is tighter than we wanted.
Anyway, enjoy your new master kit! And I hope the install goes smoothly for you.
Matt@Tick is offline   Reply With Quote
Old 08-29-2018, 02:46 PM   #6
Michaelthurston
Michaelthurston's Avatar
Drives: 2013 Vert Ashen Gray
Just swapped my v6 master cylinder for the SS master cylinder, and it's super simple. In a nutshell:
1. Use a siphon/pump to remove the fluid from the master cylinder reservoir.
2. Loosen the two brake lines on the left hand side of the Master cylinder. (I would suggest putting something beneath to catch any remaining fluid, as given enough time, it will eat paint.)
3. Remove the two nuts and washers on either side of the master cylinder, holding it to the brake booster.
4. Bench bleed your new master cylinder to remove all the air.
5. Install the new bled master cylinder following the above steps in reverse order.
Then just make sure you fill it back up with enough fluid.
Let me know if you have any other questions, happy to help.
Michaelthurston is offline   Reply With Quote
Old 09-02-2018, 08:44 AM   #7
booneSS13
booneSS13's Avatar
Thanks a lot man! So how exactly do you get to the master cylinder from inside if the car??
Sent from my VS988 using Tapatalk
Romans 5:8
Old 09-02-2018, 09:59 AM   #8
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Check this out
camguynj is offline   Reply With Quote
Old 09-03-2018, 06:23 AM   #9
Nb1081
Drives: 10 2ss/rs
When you bench bleed the master do not push the plunger all the way use a bunch of short strokes and i would bleed the lines on car incase you got any air in there plus it never hurts to get fresh fluid in the whole system
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
Old 09-22-2018, 05:56 PM   #10
booneSS13
booneSS13's Avatar
Does the driver seat have to be removed to be able to remove the clutch pedal assembly?
Romans 5:8
Old 09-22-2018, 08:20 PM   #11
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Is he talking about the Brake Master Cylinder or the Clutch Master Cylinder??
Orange Krush II
