Old 09-01-2018, 07:42 AM   #1
nateglover
Drives: 2015 2ss 1978 camaro
Ecs supercharger stock bottom end hp help
I have a 2015 l99 ss convertible ecs supercharger, stock bottom end, long tube headers, zl1 fuel pump, deatschwerks 90lb injectors, axle back flowmaster exhaust and dyno'd at 421rwhp on a dyno dynamics at 8-9psi... does this sound right?
nateglover is offline   Reply With Quote
Old 09-01-2018, 07:52 AM   #2
hou30guy
Drives: 2011 convertible 2ss/rs
Nope
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 09-01-2018, 07:53 AM   #3
hou30guy
I made that exact same whp with l99 delete, lt headers, cai, cam, exhaust, tune
Old 09-01-2018, 07:54 AM   #4
hou30guy
You should be at 500 to 575 whp minimum
Old 09-01-2018, 07:59 AM   #5
nateglover
Im wondering what the problem could be... i know they supposedly read low but thats entirely too low. Any suggestions?
Old 09-01-2018, 08:11 AM   #6
hou30guy
No cam?
Old 09-01-2018, 08:22 AM   #7
nateglover
hou30guy no cam at all just stock motor ecs kit 90lb injectors zl pump longtube and axle back
Old 09-01-2018, 09:31 AM   #8
hou30guy
Did he tell you what the timing was at wot
Old 09-01-2018, 09:40 AM   #9
nateglover
No i dropped it off a couple days ago and picked up yesterday and i asked i can ask on monday. He also said he was trying to be conservative on it.
Old 09-01-2018, 10:25 AM   #10
hou30guy
If that's the case he took conservative to a whole new level
Old 09-01-2018, 03:36 PM   #11
nateglover
Lol thats very conservative. I was also thinkin belt slipping or the restrictor plate thats in it, but the plate still shouldnt restrict it that much. Or maybe the heat, it was like 80s/90s this week. 2 buddies of mines had theirs dyno'd also... a6 d1sc procharger with cam 487ish and the oda m6 Kooks long tube headers with high cats, flow master outlaw exhaust, D1SC procharger kit...also have suspension stuff done...it’s now making 550-580 wheel roughly the same in torque. He also said add 18% to it... so it would be about 500
Old 09-01-2018, 03:53 PM   #12
hou30guy
Take that restrictor off and as far as the belt slipping he should have seen that on the dyno, but u can do ur part by making sure its the tightest belt on there max that tensioner out
Old 09-01-2018, 07:12 PM   #13
One Bad Vette
One Bad Vette's Avatar
Drives: 2013 Victory Red 2SS 1LE
He said add 18% for driveline loss so he’s trying to get you to estimate crank horsepower. No matter how he tries to sell it to you, that number is crazy low. I’d be giving your tuner the “what for”.
James
One Bad Vette is offline   Reply With Quote
Old 09-01-2018, 09:42 PM   #14
TheInfamouSS
@LS.ACE
TheInfamouSS's Avatar
Drives: 2014 Chevy Camaro 2SS/1LE
Dyno Dynamics are known to show between 12-16% difference than a dyno jet. 12% is the general consensus for the most part though. Even then it seems low still.
Some weird snail with a belt on it | Tial Q Bov | CCP Jam Cam | Stainless Works 1 7/8" Headers to Custom 3" Exhaust | Alky Control Dual Nozzle| ProMeth Trunk Mount Tank | Melling Oil Pump | DSX Aux Pump | id1050x Injectors | McLeod RXT w/ Monster Billet Release Bearing | ZL1 3.73 Rear Diff | BMR Delrin/Poly Diff Bushings | DSS 1-Piece Aluminum Driveshaft | ZL1 Axles | Metco Driveshaft Loop | BMR Adjustable LCA's, TA's, Toe Rods | BMR Adjustable Sway Bar w/ Fe3 End Links | Mickey Thompson 305/35-20 Street S/S Drag Radials |
TheInfamouSS is offline   Reply With Quote
dyno, ecs, novi, supercharger
