Old 09-03-2018, 01:28 PM   #1
richard grimsley
GRIM
Drives: 2015 Camaro Z/28
Lowered Z28~
I just picked up a “15 Z28 and was looking into upgrade potentials. Has anyone placed lowering springs on their Z?
If so, pictures and or dropped by how much?
richard grimsley is offline   Reply With Quote
Old 09-03-2018, 03:15 PM   #2
pat_t
Drives: .
Seen a few lowered slightly on proper expensive race coilovers.
Not seen any dropped on springs on the Multimatic DSSV Dampers. Probably because unless you had a set of Z/28-spec springs custom wound it would be a handling downgrade!
I'm looking into a way of lowering mine a few mm at the front, but it means modifying the strut, so it won't be for everyone!
pat_t is offline   Reply With Quote
Old 09-04-2018, 07:33 AM   #3
Smokin19
Drives: 19' ZL1 A10, w/pdr
With a 3" exhaust on mine I don't think I could possibly be any lower without hitting everything on the road.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/Gesi cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
Smokin19 is offline   Reply With Quote
Old 09-06-2018, 07:57 PM   #4
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
A member here on the forums, aris, has installed the Detroit Speed Kit 1 on his Z/28. Search for him, he has some info within some posts. I have the Z suspension on my ‘14 1LE and I use 19” wheels for the track. I wish I could lower it and not lose any performance. I actually ran a set of BMR 1” drop springs with the DSSVs 2 years ago. I believe it was a step down, but I did not have the optimum anti roll bar package either. Plus, my track skills have got a lot better since them. A few vendors have sworn the DSE Speed Kit 1 is a great setup on the Z, but I need more proof of the track performance.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather
cdb95z28 is offline   Reply With Quote
Old 09-06-2018, 08:01 PM   #5
cdb95z28
cdb95z28's Avatar
Also, the DSSVs have less compression travel (and rebound travel). So reducing travel with drop springs will mean the car is on the bumpstops more. There are many dynamic factors here.
Old 09-07-2018, 11:22 AM   #6
aris
Drives: Z/28
cdb is correct that I have installed the DSE speed 1 kit on my car. The kit lowers the car just under an inch all around (I think .75"s). I'm also running moreno camber plates.
I've never felt the car bottom out on the bump stops on the track, but its entirely possible that it could occur on a bumpy road. Hasn't been an issue for me.
It's bizarre to me how controversial running different spring and sway bar rates is, but to each his own. It's an afternoon of work to go back and forth between different springs and sway bars.
There are obviously many factors at play, including improvements in my own skill level, but I experienced a net improvement in performance (based on average lap times at Thunderhill's 3 mile course) between the car stock and the car modified with the speed 1 kit and the camber plates. I found the car was a little more predictable and that turn in greatly improved (probably mostly due to the camber plates).
We'll see how long I leave the suspension as is. I like experimenting with different setups, so it's more than likely that I'll eventually switch to something else.
aris is offline   Reply With Quote
Old 09-12-2018, 05:57 PM   #7
D2M
D2M's Avatar
Drives: Z/28
Lowered slightly over 1 in.
D2M is offline   Reply With Quote
Old 09-12-2018, 07:54 PM   #8
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
How was it lowered?
69L48Z27 is offline   Reply With Quote
Old 09-12-2018, 10:46 PM   #9
D2M
D2M's Avatar
Drives: Z/28
Originally Posted by 69L48Z27 View Post
How was it lowered?
My car is retired from track duty. I installed Pedders Supercar coilovers with my existing Moreno camber plates as they do not require drilling the rear floor for dampening adjustment access and are the adjustment knobs are easy to get to..
Old 09-13-2018, 09:05 PM   #10
OneBadZ/28
Drives: 2014 Z/28 Red/AC #56
Dude that looks great! I have a hard enough time managing mine at stock height but DAMN that looks good-strong work........
OneBadZ/28 is offline   Reply With Quote
Old 09-18-2018, 10:47 AM   #11
1970judge
Drives: 2015 Z/28, 2007 HHR
You have my attention... Is Moreno still making the plates? Also, just to verify what kit # did you buy? I was just looking at their kit window shopping. This one? 033021 https://www.detroitspeed.com/2010-20...up#tab-reviews
1970judge is offline   Reply With Quote
Old 09-18-2018, 01:40 PM   #12
Spyglass
Drives: Too many
D2M, Your car is straight up fire. Love the stance.
Spyglass is offline   Reply With Quote
Old 09-18-2018, 03:04 PM   #13
Jeff71
Drives: 2015 Z/28 #1251
Gen5diy is supposed to be offering remakes of the Moreno units, see here:
https://www.camaro5.com/forums/showthread.php?t=526292
Also, it looks like the DSE speed kit PN: 033023 would be the one for 14-15 Z/28's, however, aris could have used one of the others I suppose.
Jeff71 is offline   Reply With Quote
Old 09-18-2018, 05:53 PM   #14
aris
Drives: Z/28
Nope, you're right - the correct kit is 033023
Spring rates are similar to stock Z/28, but the sway bars are much larger/heavier duty. I also upgraded the sway bar bushings and brackets that came with the speed 1 kit with delrin bushings and billet brackets.
