Old 09-05-2018, 04:33 PM   #1
stateroadhog
Drives: 2015 SS/RS 1LE
dreaded PO420
Installed set of solo hi flow cats. CEL pops every so often. Do have small leak on each flange. Is the leak at flange causing the Light? If so can I install two gaskets to help with seal? I have the rear extensions on the sensors.
stateroadhog is offline   Reply With Quote
Old 09-05-2018, 06:33 PM   #2
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
I'd seal it up, but I'm certain it's your cats. They aren't as efficient at cleaning up the exhaust as a factory cat.
JerTM is offline   Reply With Quote
Old 09-05-2018, 07:32 PM   #3
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
This code is from the hi-flow cats for sure, it will always come up. Take it to someone that can tune the car and turn off the reporting of his code.
zz430camaro is offline   Reply With Quote
