Old 09-08-2018, 12:33 AM   #1
SSkat
SSkat's Avatar
Drives: 2010 Camaro 2SS
Will 2014 NPP work on 2010?
I have 2010 SS and have the chance to buy a npp catback from a 2014 and just wanted to make sure it will fit. Also if I don’t hook the vacuum lines up the muffler will stay in loud mode right?
SSkat is offline   Reply With Quote
Old 09-08-2018, 05:59 AM   #2
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
The NPP will fit, you will need the 2013 rear lower body panel for the dual tips. The mufflers are always in open mode until you put vacuum to them so the answer is yes, it will be in loud mode. Dont waste your time hooking up the vacuum lines, you will end up taking them off, LOL
zz430camaro is offline   Reply With Quote
Old 09-08-2018, 12:32 PM   #3
SSkat
SSkat's Avatar
Appreciate it! Yeah I won’t be hooking up the vacuum lines then haha. I have borla s type catback with LTs and HFCs and I wouldn’t mind it being a tad louder
Old 09-08-2018, 12:34 PM   #4
zz430camaro
Drives: 2015 1LE
Not sure how much louder it will be but the NPP is pretty much a drone free proven exhaust system! Sounds good too.
Old 09-08-2018, 01:47 PM   #5
SSkat
SSkat's Avatar
Yeah that’s why I want it! My s type drones from 1800-2k and plus I want dual tips
Old 09-08-2018, 11:30 PM   #6
Silveradoss573
Banned
Drives: Camaro 1LE
My 1le had the fuse pulled when I bought it. Drove it from KS to mid Mo and it had zero drone. You'll like it no question.
Silveradoss573 is offline   Reply With Quote
Old 09-09-2018, 08:38 AM   #7
91 zeee
Drives: 2014 SS
Zz430 is exactly right. Also they do make kits to make the valves active, but, I agree, no need. It sounds great with the valves open.
When you take the rear diffuser off make sure you put tape on the painted surfaces of the bumper to protect it fro. Your pry tool (plastic trim pry tool is best).
91 zeee is offline   Reply With Quote
Old 09-10-2018, 06:41 AM   #8
Rich2010
Drives: 2010 Cyber Gray LS3 SS/RS
I just took my time with a Dremel and trimmed my factory diffuser. Looks good and saved me $100. Pretty simple.
I didn’t trim the hole straight down, I left a piece connected under the tips so I didn’t have to build a brace to stop it from flopping around.
2010 Cyber Gray LS3-BTR stage 4-480/428 RXT and 3.91’s
Rich2010 is offline   Reply With Quote
