![]() Drives: 2010 camaro ss Join Date: Sep 2018
Msd fuel pressure controller 2351 help
Hey everyone, just picked up a 2010 Camaro ss supercharged, it has the MSD BAP 2351, it didn't come with the cable or software, any idea where I can get that?
Thanks |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
Best place to start would be by calling MSD.
'It's an experiment'
It uses this usb cable:
https://www.amazon.com/AmazonBasics-...ef=mp_s_a_1_14 And this software: https://www.holley.com/support/resou...ware_Downloads Docs: http://documents.holley.com/2351.pdf When using the software, you need to unplug the connector from the unit then, use the USB cable... -Don
747 RWHP 794 RWTQ
#4 | |
-Don
747 RWHP 794 RWTQ
#6 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
I noticed you called it a fuel pressure controller which it is not. It is a voltage booster that supplies a constant 14.5 volts and should raise the voltage to 17.5 volts when in boost. It helps the FPCM do a better job at spinning the pump but has no direct control over the pressure. If your fuel pump is stock you should seriously consider upgrading according to your HP goal. Ted. |
#7 | |
This! VERY important as your fuel pressure desired is controlled by the PCM/ECM and partially by FPCM (FPCM can only give what its programmed/set for) -- you'll want a setup that can give you what you need... -Don
747 RWHP 794 RWTQ
#8 |
![]() ![]() Drives: '10 T/A Conv, '10 2SS, '77 SE T/A Join Date: Dec 2015
Old thread, but I want to download the software for my MSD BAP 2351 so I can attempt some diagnostics to test the BAP to determine if it is possibly not functioning correctly and leading to my start and stall condition. The link takes you to a laundry list of selections, but which one to download?
