![]() Drives: 2010 2SS/Rs Package Join Date: Apr 2018
Tire Monitor Service
Getting the tire monitor service error. I tried to do this.. And never got past the first tire it never honked.
Any ideas greatly appreciated. Press the “Menu” button on your turn signal lever Change the display on the dash until tou see the tire pressure information PrPress the “Set” button on the end of your turn signal lever to start the recalibration. It ask you if you would like to start the recalibration, select “Yes” The horn will sound twice informing you the process has started Start with the driver front tire and release 3-4 PSI, the horn will sound once Go to passenger front tire, release 3-4 PSI, the horn will sound once Go to the passenger rear tire, release 3-4 PSI, the horn will sound once Go to the drive rear tire, release 3-4 PSI, the horn will sound once, and then twice to signal sync is complete Check the dash to confirm the “Service Tire Monitor System” message has cleared Refill the tires to the proper pressure ![]() Sent from my SM-N950U using Tapatalk |
Last time this happened to me was when I put new wheels on. I simply just went to Discount Tire and they recalibrated the sensors for me.
![]() Drives: 2012 Camaro SS Join Date: Oct 2016
Letting air out never did the trick for mine, picked me up a tool from amazon for 15$.
https://www.amazon.com/Tire-Pressure...+TPMS+Re-learn Change tires and wheels regulary so its a life saver except on the z28 replicas, with the stems in the middle of the rim. Those you gotta position good to get all 4 in one go. |
Also depending on the age of the TPMS sensor they could need replacing. Just a thought if you cant get them to read. I had a set that the batteries lasted less than 3 months off Amazon.
