Old 09-11-2018, 09:30 PM   #1
robertebob
robertebob's Avatar
Drives: 2012 2SS/RS Convertible
2012 SS Convertible Top Issue
Sorry if this has been asked before. My 2012 convertible has had all it's water management problems fixed. But a new problem has surfaced and the top no longer operates. The issue seems to be with some kind of brace or something positioned at the center of each side of the rear window. On the right side, I can feel a square or rectangle part under the canvas. On the left side (driver side), I cannot feel that part and this side is lower than the passenger side, so it has this wonky look to it. I feel like this part has slid down and is causing a blockage of the top operation mechanism. Any info you have would be appreciated. I'd like to know your thoughts before I spend an enormous amount of money to have it diagnosed and fixed.
2012 2SS/RS Convertible, Black Exterior, Black Top, Orange Seats, Orange Hood Stripes, Hurst Short Throw, 20" Polished Aluminum Wheels
VIN 2G1FT3DW0C9126380
08/11/2011(1100) (1102)
08/26/2011(2000) (2500) (3000)
09/09/2011(3100) (3300) (TPW 9-19)
09/15/2011(3400)
09/23/2011(3800) (4000) (4150)
09/26/2011 (4B00) (4B00) (4200) (4200) (4300) (4300)
09/27/2011 (4B00) (4200) SHIPPED!
10/02/2011 (4B00) (4800)
10/04/2011 5000 Vehicle delivered/Picked up 10-5
robertebob is offline   Reply With Quote
Old 09-13-2018, 01:26 PM   #2
bwk1971
Res Ipsa Loquitur
bwk1971's Avatar
Drives: 2013 Camaro SS Vert Supercharged
This could possibly be the dreaded fifth bow issue. Do a search, you will find tons of information regarding that issue. It was a common problem on convertibles built before 2013 I believe.
"STREET LEGAL" 2013 Camaro 2SS/RS LS3 Convertible -- 2.9l Whipple Supercharger, CDC SportBar, Cordon CR-1 and MRR M017 wheels, Hex Vents, RPI ZL1 Splitter, CAI, Pfadt Tri-Y Headers, high-flow cats, ZR1 3 bar map sensor, ZL1 fuel pump, 3.875" pulley, ADM FPCM, 1LE PCV Oil Separator Kit, Elite Catch Can, APEX scoop and washer bottle relocation kit, Hotchkis lowering springs, BMR sways, BMR toe rods, BMR trailing arms, 620 rwhp, 564 rwtq, and tuned by Andrew Zurick of Complete Street Performance by way of Maryland Speed.
bwk1971 is offline   Reply With Quote
Old 09-14-2018, 09:22 AM   #3
c-57d
Drives: 14 2SS/RS Triple Black Ragtop LS3
I know that you said that the water management issues have been addressed. Could you post a few pic's of what's going on?
-E.N.
Come see the violence inherent in the sysadmin.
c-57d is offline   Reply With Quote
Old 09-14-2018, 10:01 AM   #4
robertebob
robertebob's Avatar
Picture of Wonky Top
-E.N.
I feel bad about a mistake I've made, but the top does actually function. The last time I brought it in for service, they didn't return that pull-out thing to its outward position. However, the rear window is wonky like I described in my original post. Here's a picture. The left side of my rear window droops down.
09/15/2011(3400)
Old 09-14-2018, 11:41 AM   #5
robertebob
robertebob's Avatar
A Diagnosis - Somewhat?
I just returned from a convertible top repair place. He thinks a couple of screws have come loose from the bracket I mentioned and would be an easy fix. However, he said that the rubber strip below the window that runs the width of the trunk should not be showing as much as it is. Recommendation was to take it back to the dealer.
09/15/2011(3400)
Old 09-17-2018, 01:30 PM   #6
bwk1971
Res Ipsa Loquitur
bwk1971's Avatar
Not sure if you overlooked my first reply, but I'm pretty sure you are dealing with a bent 5th bow. There's plenty of posts that discuss this problem and some have actually repaired themselves. Here's a post that discusses the signs/symptoms of this problem. Good luck with the repair. Search the convertible section for more information and possible tips on DIY repairs.
https://www.camaro5.com/forums/showt...hlight=5th+bow
Old 09-17-2018, 02:36 PM   #7
robertebob
robertebob's Avatar
I did see it before I took my trip to the convertible top guy. I started poking around and found some really good info on the 5th bow issue, one of which had pictorial details on what the problem looks like and how he fixed it. I agree with you, I've got the 5th bow disease. Thanks for your opinion because it did get me going on research.
09/15/2011(3400)
Old 09-19-2018, 02:27 PM   #8
bwk1971
Res Ipsa Loquitur
bwk1971's Avatar
Glad to hear it and good luck with the repair! On the bright side, you can just go topless all the time. Hope it works out
Old 09-26-2018, 03:35 PM   #9
bsimms89
bsimms89's Avatar
Drives: 2012 SS/RS Vert & 2017COPO#23 SC350
Not to derail the topic, but when did you have your water management issues fixed? Was it withing the warranty period, and if not did chevy do anything to help you with the repairs? I am currently going through this and chevy and the dealer are basically saying yes it was a known design issue and they issued replacement parts, but I have to pay out of pocket for it since it's out of the 3 year warranty period
2012 IOM Camaro Convertible 2SS/RS, A6/L99, ARH Longtube headers, high flow cats, x-pipe & mufflers
CAI Cold Air Intake, Kaltech Tuned
2017 COPO #23 Black w/ Supercharged LSX350
2014 Raptor 6.2L Tuxedo Black Metallic w/ 2.9L Whipple, 78Lb/hr fuel injectors, Ford Racing Dual 65mm cobrajet throttle body, kooks headers & exhaust.
1969 Camaro SS (original SS350), Black w/ white Rally Stripes, new ZZ502ci 502hp motor, muncie 4 speed, 4.11 rear
bsimms89 is offline   Reply With Quote
Old 09-26-2018, 09:09 PM   #10
robertebob
robertebob's Avatar
My WMS issues revealed themselves within the warranty period, thank goodness. Still no leaks to this day, although I think I do have the 5th bow problem so prevalent for our generation of Camaro.
09/15/2011(3400)
