Flying da helicopter
I just moved to Hawaii and realized they don't like modified cars. Apparently my car is too low (ridetech coilovers) and the only way to pass this stupid safety inspection is to change out my shocks/springs. Does anyone know a good setup that won't cost me an arm and a leg? I have a 2010 Camaro SS with FE4 rear lower control arms. Thanks in advance for any help.
#2 | |
Or try to max out ur coilovers
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS RS Join Date: Nov 2011
someone is selling some z/28 dssv shocks/springs on facebook marketplace
https://www.facebook.com/groups/3010...79849382&rt=11 |
My coilovers are maxed out already. I appreciate the ideas. This will be a temporary fix for the car until I move back to Texas in a couple years. Every time you think you're finished spending money on your car, something like this comes knocking on your door.
If I'm not mistaken, these should work for me right? I already have upgraded sway bars/endlinks and FE4 lower control arms. I think this should be a simple swap and alignment.
https://www.camaro5.com/forums/showthread.php?t=537512 |
#6 |
Yes they will work but they will still lower the car about 3/4 to 1 inch if memory serves me correct and will ride very stiff.
Orange Krush II
#7 |
![]() Drives: black Join Date: Mar 2017
Pardon my ignorance but why don’t you just keep your car plated where it was? Then you don’t have to adhere to Hawaii’s rules, cars are covered by the laws of the state they are plated in.
Inspection stuff etc should be waved because if military duty as well I would think. I know my jarhead friend had a lowered, tinted, no cat terminator in Cali and because it wasn’t plated in Cali the cops couldn’t do anything about it. |
#8 | |
#9 |
Engineer
Drives: 2014 Camaro 2SS RS 1LE Join Date: Jun 2015
How many miles on the ridetech coils? I have 1LE shocks + BMR springs that i was going to trade for stock SS suspension + cash. Maybe I can throw in some cash and get your coils?
#10 | |
#11 |
I have maybe 5 or 6k miles on them. I’ve only had them for about 4 years and half of that it was parked in a garage during deployments. I’ll let you know what I end up doing. Thanks
#12 |
![]() ![]() Drives: 2018 ZL1 2015 1SS 1LE Join Date: May 2013
I have a set of shocks, struts and springs off a 2015 1LE with 14k miles on them sitting in my garage. Nothing wrong with them just changed out to Pedders coil overs. $300 plus the ride and their yours.
2018 ZL1 2015 1SS 1LE Stock...ish |
#13 |
I’ll let you know by next week. Thanks
