Old 09-21-2018, 10:56 AM   #1
ZZZTOPZZZ
ZZZTOPZZZ's Avatar
Drives: 2013 L99 2SS Vert
Cam Motion
I'm looking to get a new cam in my LS99 that's somewhat compatible with my Procharger. I've been reading the reviews about Cam Motion and they look pretty solid. Any pluses or minuses about these guys?
ProCharger Stage II - Stainless Works Headers - Long Pipes & Cats - ZL1 Fuel Pump - Cam On The Way Next Spring
ZZZTOPZZZ is offline   Reply With Quote
Old 09-21-2018, 01:53 PM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I have nothing but good things to say about them. I wanted a smaller turbo cam because I was tired of the low RPM bucking. I called and talked to Bob (I think) and in about 10 minutes he speced me out a cam.
Upon install and tuning, it was exactly what I was after.
I called a few months later to thank him and ask him a question about valve springs. The conversation quickly went over my head but my question was answered.
I highly recommend them.
Old 09-21-2018, 04:19 PM   #3
ZZZTOPZZZ
ZZZTOPZZZ's Avatar
Thanks, that's encouraging. Can you give me a 'ballpark' figure on just the installation labor costs? I already have the hardware priced out.
Old 09-21-2018, 04:28 PM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
$0.00
I did it myself.
Most shops are around $100/hr for just labor. It is best to call various shops and ask them how much a cam swap (and tune if you are going to use the shop) is.
There is an EXCELLENT cam swap how to guide on this site I have used a couple of times.
https://www.camaro5.com/forums/showthread.php?t=125123
If you DIY, I do suggest one of these to help install the front cover:
http://www.saccitycorvette.com/AlignItTools.html
Well worth the peace of mind to prevent leaks in my opinion.
Old 09-24-2018, 05:15 PM   #5
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
I have used them for many years cant go wrong
1fast is offline   Reply With Quote
Old 09-25-2018, 01:18 PM   #6
ZZZTOPZZZ
ZZZTOPZZZ's Avatar
What I would like to accomplish is to ditch DOD and retain VVT if at all possible. Here's what Bob at Cam Motion offered:
Cam grind number LS VVT Chevy.
XA214/325-XA228/325-116+6.
Lift with 1.7 intake .552" / exhaust .552".
Duration at .050" intake 214 / exhaust 228.
Lobe separation 116 with 110 intake centerline.
Cam is $430 and will take about one week to make.
We have a DOD/AFM delete kit for $448 and it contains:
Head Gaskets
Crank Bolt
Head bolt set
Full lifter set
Lifter trays
Replacement valley cover
Exhaust gaskets.
PCV hose and plug.
Old 09-27-2018, 12:02 PM   #7
ZZZTOPZZZ
ZZZTOPZZZ's Avatar
$0.00
I did it myself.
Blake,
Question or two: Is this your daily driver and if so how does it react in traffic? My ride only comes out on nice sunny days and is put up for the winter. I'm left wondering how it will get along with the Procharger. Also, did you do any work on your heads? I'm wondering if the only difference between the LS3 and LS99 heads is the compression ratio. What do you think?
Thanks for your input,
Tom
P.S. I just turned 78 last week and just getting my feet wet again. The last time I fooled with this stuff it was on flathead Fords - waaaayyy back.
Old 09-27-2018, 02:19 PM   #8
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Originally Posted by ZZZTOPZZZ View Post
Blake,
Tom
Hi Tom,
My car is not a daily driver. It is a 1400hp twin turbo 427 with CNCed LS7 heads. It could be a daily driver but I would get tired of stopping at the gas station every day or two because it run primarily on E85. But, I literally just sold it to a local guy so if I miss it, I can go visit.
After I changed the cam, it had much nicer low speed manners. The prior cam bucked quite a bit and made stop and go traffic just short of a nightmare. The cam and tune will dicate it's manners. Even a relatively big cam can be tamed by a competent tuner.
A procharger is a nice addition to any camaro.
The head castings themself are the same. Valves are different and the springs might be due to the cam difference. The L99 has AFM (active fuel management), VVT (variable valve timing) and lower compression. If it were me, I would do an LS3 conversion and get rid of AFM. You can keep VVT if you want though.
-Blake
Old 09-27-2018, 07:57 PM   #9
ZZZTOPZZZ
ZZZTOPZZZ's Avatar
Blake:
Thanks again for your input. What's your next project?
Tom
Old 09-27-2018, 08:13 PM   #10
blake-b
blake-b's Avatar
Drives: 2009 ZR1
C6 ZR1
Old 09-28-2018, 02:42 AM   #11
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Wow, first I’ve heard of this... enjoy the next project... I’m looking forward to getting my crate back up and running...
Hi Tom... I’m not as knowledgeable as Blake, but I pop into different threads now and again... if I can ever help, gimme a shout...
Robert
Old 09-28-2018, 06:51 AM   #12
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Robert
Hi Rob!
It was very difficult to sell it but I realized I was always looking for things to change or do to it even though there was nothing left to do. To me, that meant it was time to let someone else enjoy her
Not as knowledgeable! Ha! You're too kind! Considering you literally have the fastest 5th gen on this site...
Old 09-28-2018, 09:46 AM   #13
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
Ha I thought his car was bolt ons. j/k Best wishes blake-b on new project!
After I changed the cam, it had much nicer low speed manners. The prior cam bucked quite a bit and made stop and go traffic just short of a nightmare. The cam and tune will dictate it's manners. Even a relatively big cam can be tamed by a competent tuner.
ZZZTOPZZZ what he said. Not much more can add to that. Right Cam selection and Tuning is the Key.
Car here is built for 1/2 mile and Street Have very little to 0 bucking with a M6 and still get 19 mpg on Highway at 75. Wont talk about around town lol Car wasn't built for mpg lol. Best wishes
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
Old 09-28-2018, 01:56 PM   #14
ZZZTOPZZZ
ZZZTOPZZZ's Avatar
Rob & Blake,
Ran this by the 'Boss' yesterday, and yes, even at my age it seems you still have to get permission to play with the toys. I got the familiar eye roll like 'will this ever end', so I just sat there as she wanted to know 'how much this time' for the car that just doesn't get used very much. I said something about how her brother has 5 boats and doesn't use any of them very much. Bottom line is she's on board. The fellows over at Motor City Racing here in my town will be doing the job. It looks like a spring project as I never put my baby on a Michigan road in the winter.
Thanks again for the help and encouragement.
Tom
