Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Suspension / Chassis / Brakes
Old 09-23-2018, 10:30 AM   #1
paul3078
paul3078's Avatar
Drives: 2024 Nitro Yellow 1SS 1LE
2015 SS DEMOD sale
I have the following for sale:
Metco driveshaft loop SOLD
Spohn lower control arms, trailing arms and toe links with poly bushings
paul3078 is offline   Reply With Quote
Old 09-24-2018, 12:13 AM   #2
derieu
Engineer
derieu's Avatar
Drives: 2014 Camaro 2SS RS 1LE
Metco driveshaft loop, Spohn lower control arms, trailing arms and toe links with poly bushings, race star recluse 17x4.5 w/28x6x17 m&h dot bias skinnies and 17x10.5 325/45R17 M&H drag radials, 8 passes very little burn out time (not needed, hook great) Most of the suspension and drive train parts have under 1k miles on them
Moving up to a 6th gen so need this back to stock to sell, unless someone wants the whole car. 15 ss Green flash edition 14K miles, many other upgrades as well, contact for info.
What color for the spohn arms? I wish they were the del-sphere ends instead of poly... Might still be interested
2014 Red Hot Camaro 2SS RS 1LE
-Sunroof Delete, Recaro, Nav, NPP
-Pegasus Subframe Bushings, JPSS Radius Insert, Detroit Speed Caster Mod, PMAS Intake, Solo High Flow Cats, Ecsta PS91 Tires, MGW Shifter, Pegasus Offset Poly Diff Bushing
derieu is offline   Reply With Quote
control arm, spohn, toe, trailing
