Old 09-24-2018, 06:13 AM   #1
11ss28086
Drives: 2011 ss camaro
Moser m9 fabricated rear
Anyone use this hows it work any comments plz
11ss28086 is offline   Reply With Quote
Old 09-25-2018, 09:20 AM   #2
TheInfamouSS
@LS.ACE
TheInfamouSS's Avatar
Drives: 2014 Chevy Camaro 2SS/1LE
This isn't my area of expertise but since you've been waiting forever I thought I would give you some type of answer. All I know is it takes some cutting, welding, and you need to get rid of your gas tank and switch to a fuel cell.
I know Kyle Hirt has done it, you can find him on facebook or on instagram @camarokyle. At least it might be someone that can give you a little more information about what it all takes.
Some weird snail with a belt on it | Tial Q Bov | CCP Jam Cam | Stainless Works 1 7/8" Headers to Custom 3" Exhaust | Alky Control Dual Nozzle| ProMeth Trunk Mount Tank | Melling Oil Pump | DSX Aux Pump | id1050x Injectors | McLeod RXT w/ Monster Billet Release Bearing | ZL1 3.73 Rear Diff | BMR Delrin/Poly Diff Bushings | DSS 1-Piece Aluminum Driveshaft | ZL1 Axles | Metco Driveshaft Loop | BMR Adjustable LCA's, TA's, Toe Rods | BMR Adjustable Sway Bar w/ Fe3 End Links | Mickey Thompson 305/35-20 Street S/S Drag Radials |
TheInfamouSS is offline   Reply With Quote
Old 09-25-2018, 12:37 PM   #3
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
Moser does make an after market rear that is a direct replacement for the stock rear, no welding needed. It does need new axles also. A friend of mine has done it to his 2010 Camaro SS. He does drag race it often.
sscamaro is offline   Reply With Quote
