![]() Drives: 2012 45th edition RS 2LT Join Date: Jul 2014
Leaky trunk fix
Hey fellas with all the rain we’ve been having here where I live I thought maybe some of you guys have encountered the same issue I did and that is a trunk that leaks. I think I found the fix. It is a drain tube located inside the trunk on either side up towards the rear shelf. In my car the tube was not inserted completely into the nipple that leads to the outside. I have attached a couple of pictures. One shows the disconnect and the other show the connected. Hope this helps out. Cheers.
MG] ![]() ![]() Sent from my iPhone using Tapatalk Last edited by Niceun; 09-28-2018 at 09:03 AM. |
old school chevy rodder
That would be from the sunroof...…...
![]() Drives: 2015 Camaro 2SS Join Date: Oct 2016
That's not good, glad in a way my latest one hasn't got a sunroof.
![]() Drives: 2010 Camaro 2SS Join Date: Mar 2018
Tube
I'm having the same problem, where can I purchase that drain tube? mine is missing.
Op, if you only connected back still keep an eye on it. If it's like mine it will continue to come disconnected on it's own. Mine happens to always be the passenger side. You may have to put a clamp, zip tie or something around it to keep it connected.
#6 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
I would have put some silicone weather strip glue on it to hold it in place...
The Bird is the word! |
#7 |
Good ideas guys. I will definitely do one of them. As far as where to purchase the drain tube I have no idea. Maybe the auto parts store would have some type of tube that would work.
#8 |
![]() ![]() ![]() ![]() Drives: 2024 Camaro 2SS CE Convertible Join Date: Jul 2013
Yeah, checked that. It was connected in mine. The only thing I think of is I had the trunk packed too tight and had the bag pushed up. Hasnt done it since.
#9 |
![]() Drives: 2010 2LT/RS IOM Join Date: Sep 2017
I had that problem with my trunk too, I just bought a 1/2" tubing and connected the two so it wouldn't disconnect again. The tubing from the sunroof on that side just seemed too short, it would barely connect.
#10 |
Camaro- Life Member
I used bicycle tire patch glue and a small zip tie on mine, no leaks in over a year.
15 2SS/RS LS3 M6 Summit white
16 200 40mpg Vivid Blue Pearl 19 Tahoe 5.3 Boring Grey 91 Camaro RS 305 TBI 700R4 85 Corvette - TBD 05 Envoy 4.2 4x4 |
