Old 10-02-2018, 06:55 PM   #1
stang stopper
Drives: 45th anniversary camaro ss
Clutch suggestion
I`m need of a clutch ASAP what recommendations are available? The car is on nitrous (200hp progressive)and the stock clutch won`t cut it.
stang stopper is offline   Reply With Quote
Old 10-03-2018, 07:42 AM   #2
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Call Tom at Carolina Clutch.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 10-03-2018, 07:51 AM   #3
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
Center Force Dual Friction - Jegs or Summit Racing.
ZEN357 is offline   Reply With Quote
Old 10-03-2018, 07:58 AM   #4
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
How much do you want to spend?
These always get great reviews and the cost is reasonable:
https://store.katechengines.com/ls9x...maro-p220.aspx
zz430camaro is offline   Reply With Quote
Old 10-03-2018, 09:28 PM   #5
marklsx
Drives: 2014 Camaro 1SS
The Monster LT1-S twin disc looks pretty good to me. It's basically the GM clutch from the C7 with a flywheel for our cars.
2014 1SS - BTR Stg3, GMPP CNC Heads, Kooks LTs & cats, Magnaflow 2.5" Street w/Res X, Z28 CAI
marklsx is offline   Reply With Quote
Old 10-03-2018, 10:01 PM   #6
flyinglow57
Drives: rumble bee,2SS 6sp
I loke my lt1-s clutch
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not.
flyinglow57 is offline   Reply With Quote
Old 10-03-2018, 10:05 PM   #7
zz430camaro
Drives: 2015 1LE
You get the lighter flywheel?
Old 10-04-2018, 08:34 AM   #8
christianchevell
old school chevy rodder
christianchevell's Avatar
Have the monster LT1s, did tons of research before getting one, and use the steel flywheel for centrifugal; daily driver, also use the monster Billet bearing support as the stock slave needs it......and yes it accepts the stock slave, and many aftermarket,( most) don't) and it drives like stock and does not chatter like some POS clutches.... And the price is right for a dual disc that does do 700 HP and torque really...….
Old 10-04-2018, 12:13 PM   #9
zz430camaro
Drives: 2015 1LE
Out of curiosity, is there any advantage of replacing the clutch if your stock LS3 one is working OK?
Old 10-05-2018, 08:41 AM   #10
christianchevell
stock is rated for about the stock power level, you fry it too much and sometime your getting a tow until ones done basically..... stock clutch is not bad actually....its the damn throwout bearing support that melts if a clutch rider and then it can make things not work well at all....
Old 10-05-2018, 10:37 AM   #11
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I'm really happy with my spec stage 2 clutch...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 10-05-2018, 11:20 AM   #12
lazerlemonta
Drives: 2010 C6 1LT
The RPS twin carbon with aluminum flywheel is about the cats meow for performance oriented gains. It is 26 pounds complete (I have this in my C6 as the tilton wouldnt take the 1.50 60' abuse). Mamo offers a windowed steel flywheel complete it weighs 31 pounds. Wear is non existent and can completely be rebuilt. I drove a 16 pound clutch in my 5th and went 11.5@120 with my bolt on set up. The additional 10 pounds of mass would make this an easily driven clutch. Most people love the heavier clutches but i prefer not slow the acceleration down with the added MOI.
Best MPH 134.82
Old 10-10-2018, 04:18 PM   #13
Punisher_ATX
Drives: 2010 SS
LT1-S Held up great for me at 500rwhp N/A + a 150 shot non progressive for a long time. Now running their LT1-R at alot more power.
Punisher_ATX is offline   Reply With Quote
